Help on every Honda OEM sway bar sizes.
From: fountain inn, sc. where they still rock banjos on porches, usa
hi, i'm trying to make a list of all the OEM sway bar sizes. i found alot of them in the archives here and thru out other forums. but it incomplete, i was wonder if ppl here could give a hand fill in the holes. i do understand there might be a mistake here and there, that why i'm asking for help. so i can do it correctly. i've looked also on dealerships parts area too. but at times they don't list the size. please post the correction and i will correct it thank you again.
Honda OEM sway bar sizes:
2007-present Fit/Jazz: 21mm/F - n/a/R
1986-1989 All Models - 17mm/F - 17mm/R(the only reason i included it cause it was w/other info)
1988-1991 Crx HF: 17.2mm/F(hollow) - n/a/R
1988-1991 Crx Dx: 18mm/F(solid) - n/a/R
1988-1991 Crx Si: 18mm/F(solid) - 15mm/R
1988-1991 Civic Sdn: 19mm/F(solid) - 15mm/R
1992-1995 Civic Dx: n/a/F - n/a/R(coupes didn't come w/sway bars)
1992-1995 Civic VX: 19mm/F(soild) - n/a/R
1992-1995 Civic EX: 21mm - n/a/R
1992-1995 Civic Si: 21mm/F - 13mm/R (4drs Ex sdn cars did too)
1994-1997 Del Sol DOHC: 24mm/R - 15mm/R
1996-2000 Civic HX: 22mm/F- n/a/R
1996-2000 Civic EX: 22mm/F - n/a/R
1999-2000 Civic Si: 26mm/ - 13mm/R(4drs sdn cars too)
1997-2000 Civic Type R: 26mm/F - 22mm/R
2001-2005 Civic Dx:
2001-2005 Civic Ex:
2001-2005 Civic Hx:
2001-2005 Civic Lx: 25.4mm/F - n/a/R
2001-2003 Civic Si Hb: 25.4mm/F - 15mm/R
2004-2005 Civic Si Hb: 25.4mm/F - 17mm/R
2006-present Civic Dx: 25.4mm/F - n/a/R
2006-present Civic Lx/Ex: 25.4mm/F - 11.mm
2006-present Civic Si Coupe: 28mm/F(solid) - 17mm/R
2007-present Civic Si Sdn: 27mm/F(solid) - 17mm/R
1990-1993 Integra Coupe/3dr: 23mm/F - 14.7mm/R
1990-1993 Integra Sdn 4dr: 23mm/F - 15.9mm/R
1994-1999 Integra RS/LS/GS/SE Coupe: 22mm/F - 12.9mm/R
1994-1999 Integra RS/LS/GS/SE Sdn: 22mm/F - 14mm/R
2000-2001 LS/GS Coupe - 24mm/F - 12.9mm/R
2000-20001 LS/GS Sedan - 24mm/F - 14mm/R
1994-2001 Integra GSR: 24mm/F - 14mm/R
1997-2001 Integra Type R: 24mm - 23mm/R(JDM) -22mm/R(USDM)
2002-2004 RSX: 23mm/F - 19mm/R
2005-2006 RSX:
2004-present TSX:
1988-1991 Prelude: 25.4/F - 17mm/R(this the only one i question cause i rememeber pulling the both bars and they was the same size as the 90-91 Integra)
1992-1996 prelude: 24.2mm/F - 23mm/R
1997-2001 Prelude: 25.4mm/F - 23.5mm/R
2000-2001 S2000: 28.2mm/F - 27.2mm/R
2002-2003 S2000: 26.5mm/F - 25.5mm/R
2004-present S2000: 26.5mm/F - 25.4mm/R
(I posted the NSX... yeah, like we can afford them and they have a second # i didn't post. if you see the sway bar # you know. it's like 21x3mm.)
1991-1992 NSX: 18.3mm/F 17.5mm/R
1993-1994 NSX-R: 21mm/R - 17.5mm/R
1995-1996 NSX-R: 21mm/F - 19.1mm/R
1997 NSX-S, Zero and Zanardi: 18.3mm/F - 19.1mm/R
1997-2001 NSX: 18.3mm/F - 17.5mm/R
2002-2005 NSX-R: 22.2mm - 17.5mm/R
Modified by remoer at 3:58 PM 6/22/2007
2001-2005 Civic Dx:
2001-2005 Civic Ex:
2001-2005 Civic Hx:
2005-2006 RSX:
2004-present TSX:
From http://www.S2ki.com:
'00 - '01
front swaybar diameter 28.2mm
front swaybar wall thickness 5.0mm
rear swaybar diameter 27.2mm
rear swaybar wall thickness 5.3mm
'02 - '03
front swaybar diameter 26.5mm
front swaybar wall thickness 4.5mm
rear swaybar wall thickness 4.5mm
(OP said the 04-up he got from posts on the website)
'04
front swaybar wall thickness ?
rear swaybar diameter 25.4mm
rear swaybar wall thickness ?
You can double check the '03 here:
http://www.hondaautomotivepart...cgry5=
'00 - '01
'02 - '03
'04
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vitt1 »</TD></TR><TR><TD CLASS="quote">From http://www.S2ki.com:
aww come on vitt. who's the one who gave you that info on s2ki?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
LOL
Edit: "From HT's CRX Tyson who's really S2K's Tyson"
Yeap, I was a recent S2Ki.com noob
</TD></TR></TABLE>LOL
2001-2005 Civic Dx:
2001-2005 Civic Ex:
2001-2005 Civic Hx:
2005-2006 RSX:
2004-present TSX:
2001-2005 Civic Dx:
2001-2005 Civic Ex:
2001-2005 Civic Hx:
2005-2006 RSX:
2004-present TSX:
Andrei'sCivic
Mar 26, 2007 05:14 PM
martini
May 20, 2004 08:44 PM
CRexcellence
Dec 2, 2003 05:14 PM
24hourflipness
Apr 13, 2003 05:06 PM
every little bit helps.
