Front Brake Pin on EX non-abs
So I have a spare set of front brakes and I want to use them. They are from a 1993 civic EX non-abs. On one side it's missing the pins that the caliper slides on. How do they connect to the carrier? Do they screw on or press in? In the pic bellow...they are part number 24 and 18.
they slide into part # 19 and 16 and are bolted to the caliper with bolt # 21 you will also need part # 17 that is the rubber guide/seal
Thnx for the info...I went back and looked at the brakes for the first time in a year and it turns out I only needed the bolt on the end...now they are installed and work great.
B18C5-EH2
20
Aug 26, 2004 01:39 PM
abraunworth
Mar 30, 2002 04:11 PM
