need help on clicking noise on drivers side
Old Jun 7, 2007 | 11:51 AM
timmah22's Avatar
Default need help on clicking noise on drivers side
98 Accord. I have checked my axle and halfshaft as well as the bearings and everything. When I stop and go it will click a couple of times on the drivers side and cant figure it out. Appreciate anybodys help.
Modified by timmah22 at 1:58 PM 6/27/2007
Old Jun 7, 2007 | 01:14 PM
hondadude's Avatar
Default Re: need help on clicking noise on drivers side (timmah22)
just about anything could be worn out on that 79 Accord of yours.
Clicks in turns or just going straight from a stop?
single click or clickity clickity clickity?
Old Jun 7, 2007 | 06:20 PM
Schmitey's Avatar
Default Re: need help on clicking noise on drivers side (hondadude)
Classic balljoint sound. Especially when loading and unloading the suspension.
Lift the car up from the frame and grab the wheel. If there's excess play from side to side you have a bad tie rod (then locate whether its the inner or outer). If its up and down play as I suspect then it will be either your upper or lower balljoint (probably lower).
bobrae04
Jan 21, 2012 04:27 PM
kegobeer
May 20, 2010 02:32 PM
chrisw
Mar 26, 2004 08:07 AM
brads94accord
Sep 4, 2003 06:56 PM
