Accord Wont Start! Please help
Old Jun 7, 2007 | 11:51 AM
CrxSiR-GNY's Avatar
Default Accord Wont Start! Please help
my brothers 91 accord is having fuel delivery issues....what happened was we were driving around trying to get vtec to engage (this was the original problem) when all of the sudden the car just died....we let it sit for about 5 minutes then it started again but died another 10 ft. up the road...now it just cranks and does not start...it does not smell like fuel, the fuel pump DOES NOT prime before i turn the key, and the car does start if i spray starter flued into the throttle body...
i already replaced the main relayand it still has the same problem...my question for you guys is if there is anything else i should check before i drop the gas tank out to replace the fuel pump...i would really hate to do all that work and that not solve the problem....
any suggestions as to why vtec wont engage would be appreciated as well...the car throws two codes...22 and 23 (knock sensor and vtec pressure switch)...does this mean i need a new vtec solinoid?
thanks in advance for all of your help
Modified by Bigtmanx00x at 1:11 PM 6/7/2007
Old Jun 7, 2007 | 04:50 PM
CrxSiR-GNY's Avatar
Default Re: Accord Wont Start! Please help (Bigtmanx00x)
some help would really be appreciated
bump!
Old Jun 7, 2007 | 05:54 PM
Schmitey's Avatar
Not sure on the VTEC stuff...that's really not my forte.
Far as the gas issue you basically answered your own question. If its not priming then you have a problem (make sure you are getting power and its not just a fuse or something). Beat on the tank with a hammer while trying to crank it and see if it starts. This isn't always the case, but if it starts up you have a bad pump.
Before you drop the tank look under the carpet in the trunk. On my 96 at least you can get to the pump without dropping the tank. Takes all of 5 minutes!
Old Jun 7, 2007 | 07:22 PM
jjyellow's Avatar
For the vtec problem i belive you just need to change the pressure switch. I believe its around 40$.
DId you see if your car has any fire?
Old Jun 7, 2007 | 07:52 PM
CrxSiR-GNY's Avatar
Default Re: Accord Wont Start! Please help (Schmitey)
yeah i already looked into that...you do have to drop the tank to replace the pump in the 91's
thanks
Old Jun 8, 2007 | 07:50 AM
JimBlake's Avatar
Look for access panels under the back seat or under the trunk floor. Maybe you can't remove the pump that way, but if you can get to the pump's wiring you can check whether it's getting power. A good main relay won't help if the wires are broken...
If it's NOT getting power, you could bring temporary power from the battery to verify the pump actually works. Then trouble-shoot the circuit.
Old Jun 8, 2007 | 09:59 AM
CrxSiR-GNY's Avatar
Default Re: Accord Wont Start! Please help (JimBlake)
well i dropped the tank out today and what do you know...the pump does work when i jump it with a battery pack...where should i start with troubleshooting the circuit?
Old Jun 8, 2007 | 10:42 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtmanx00x &raquo;</TD></TR><TR><TD CLASS="quote">well i dropped the tank out today and what do you know...the pump does work when i jump it with a battery pack...where should i start with troubleshooting the circuit?</TD></TR></TABLE>I don't know much about exactly where the wiring harness goes thru a '91...
Use a single wire from the battery (+) to the pump. If it runs, then you know your ground is OK. Finding broken wires buried in the wiring harness is a big PITA.
Go back to the main relay. Does it actually produce battery voltage at the proper pin for the fuel pump?
Old Jun 8, 2007 | 04:35 PM
CrxSiR-GNY's Avatar
thanks for the advice...i actually got the car running a few hours ago...and it was exactally what you said...there was a break in the wire somewhere along the way between the relay and the fuel pump...i got frustrated and just ran a new wire and bingo it started up...
i still cant get any vtec though...i got rid of the code 22 and all i have now is a knock sensor code (23)
KYRGYZ
Aug 17, 2017 09:14 AM
mikeoj
Feb 10, 2014 06:20 PM
soljahsgurl
Feb 14, 2012 11:24 AM
raymondlee
Jan 22, 2008 02:13 PM
ChronicFrogs2004
Nov 20, 2004 08:02 PM
