Suspension & Brakes Theory, alignment, spring rates....
Hatch with +36 offset 15x7 rims
Old Jun 7, 2007 | 10:36 AM
Weel's Avatar
Default Hatch with +36 offset 15x7 rims
Will 15X7" +36 Offset rims clear with 195/55/15 race rubber?
Old Jun 7, 2007 | 12:58 PM
TunerN00b's Avatar
Default Re: Hatch with +36 offset 15x7 rims (Weel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weel &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, first time post in this forum.
I have a eg hatch motorsport car. I am wanting to run 15x7 +36 offset rims with 195/55/15 tyres.
Will there be any rubbing issues or will I need to run camber to the car low</TD></TR></TABLE>
If you don't roll the rear fenders, it might rub lightly back there if you're tucking tire and haven't added additional camber. My 16x7 42 offset came very close in the back, but I was also using 205/45-16 tires, which should be slightly wider than the 195/55-15s.
Old Jun 7, 2007 | 04:19 PM
Tad's Avatar
Tad
i have +35 15x7 w/ 195-50-15
fenders are definitely rolled..
imo rolling ur fenders is a must for any lowered honda
but yeah, not much rubbing,
I need to be careful with sharp tuns up driveways, and sometimes hear some rub when I hit potholes or whatever... but for the most part it's all good
Old Jun 7, 2007 | 05:14 PM
Froth's Avatar
Default Re: (Tad)
15x7 +35's running 205/50/15's with a LARGE rim lip guard. Pulled and rolled to go this low. No rubbing, but it was a good amount of work pulling/rolling.
With one finger gap all the way around I didn't need any rolling/pulling. You should be fine depending how low you plan on going.
Old Jun 7, 2007 | 06:08 PM
hayabusa160's Avatar
Default Re: (Froth)
slight tuck
15x7 35 offset. with 205 50 15 falken azenis
2.5 neg front camber 1.5 rear
my fenders are rolled front and back. the front have a slight pull for my wider 16x8s 33 offset.
Old Jun 7, 2007 | 06:12 PM
jdmjunkie562's Avatar
Default Re: (Froth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Froth &raquo;</TD></TR><TR><TD CLASS="quote">15x7 +35's running 205/50/15's with a LARGE rim lip guard. Pulled and rolled to go this low. No rubbing, but it was a good amount of work pulling/rolling.
With one finger gap all the way around I didn't need any rolling/pulling. You should be fine depending how low you plan on going.</TD></TR></TABLE>
WOWO I DIDNT HAVE THAT PROBLEM WITH MY 91 PRELUDE. THATS ONE THING I WISH INTEGRA AND HATCHES HAD FENDERS LIKE THE ERD GEN. PRELUDE
Old Jun 8, 2007 | 10:59 AM
TunerN00b's Avatar
Ok, I'll ask. how do you "pull" a fender to get more clearance? I've flared fenders, but am unfamiliar with pulling them.
Old Jun 8, 2007 | 12:46 PM
slammed_93_hatch's Avatar
Default Re: Hatch with +36 offset 15x7 rims (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I'll ask. how do you "pull" a fender to get more clearance? I've flared fenders, but am unfamiliar with pulling them.</TD></TR></TABLE>
i understand it as simply just that, pulling them out. You can get a good bit of flex just from pulling.
If you want to take it further unbolt the bolts and pull it all the way out and bolt it back down
car1115
Jun 24, 2012 09:48 PM
kirkland08
Jun 19, 2010 10:05 AM
noidg101
Jan 15, 2009 09:41 AM
shl76
Jan 10, 2007 06:22 PM
epraion62
Aug 17, 2005 02:08 PM
