Suspension & Brakes Theory, alignment, spring rates....
flca strut bushing
Old Jun 7, 2007 | 09:26 AM
phan222001's Avatar
Default flca strut bushing
ok heres the problem i have the energy suspension bushing kit and had most of the bushings but on and didnt really have time to do the rest. Recently my flca strut bushing is torn causing the car to feel real unstable in the front. For some reason the bushing is not in the box and i cant seem to be able to order jus that bushing. Does anyone know where i i can jus buy that bushing instead of getting another kit. thanks
Old Jun 7, 2007 | 11:00 AM
chrisw85's Avatar
Stay away from poly: https://honda-tech.com/zerothread?id=1563815
but to answer your questions, what car is this for? There were diff energy part number for diff flca shock bushings.
Old Jun 7, 2007 | 08:20 PM
DavidR's Avatar
Default Re: (chrisw85)
I would stay away from poly in the front, unless you've got some magic new formula of poly which can resist the wear I've seen. I would just replace them with factory bushings, or the Mugen parts.
If you replaced them with some sort of spherical bearing item, the ride would be much more harsh, and you'd probably have to replace parts more frequently.
Old Jun 8, 2007 | 09:20 AM
phan222001's Avatar
Default Re: (DavidR)
its for a 99 ek hatch and the bushing only comes in the master set i think
championR
Mar 9, 2008 03:58 PM
ZAKU
Mar 2, 2008 05:35 PM
tthomass
Suspension & Brakes
14
Mar 4, 2005 09:44 AM
makibaka
Aug 8, 2003 01:55 PM
idreamsi
Oct 18, 2002 11:21 AM
