Suspension & Brakes Theory, alignment, spring rates....
how to install strut adjuster dial
Old Jun 6, 2007 | 11:31 PM
ziptie's Avatar
Default how to install strut adjuster dial
installed my illuminas but confused on the adjusted dial. do i just hit it down into the hole? how do i know if it actually is adjusting it? it also came with 2 nuts, what are those for? i didnt come with instructions
Old Jun 6, 2007 | 11:59 PM
Tyson's Avatar
Default Re: how to install strut adjuster dial (jagoff)
install the skinny one inside. its keyed, can only go in at one orientation. then install the one with the numbers around it.
the white dot points to the setting.
nuts are for the top of the shock. replace your stock ones if you want.
fastlude69
Audio / Security / Video
Mar 1, 2004 06:11 AM
Turbo Powa
30
Oct 29, 2002 06:16 PM
CzanSOHC
Sep 6, 2002 07:46 PM
