Tenzo R 15" rims - Air Spenser Refills - Eastwood Fender Roller for Rent
Civic SI engine D16A6 for parts or rebuild
Cylinders 2 & 4 have no compression. I don't really know whats wrong with it, maybe a blown head gasket. Anyways, I swapped in a new engine and am now selling this one. Good for parts or if you want to rebuild it. The clutch and flywheel is still good and maybe needs to be resurfaced. The engine comes with everything you see in the picture. The engine was never raced, turboed, nos'ed, supercharged, any any other type of force induction.
Here are some of the stuff that I just installed in there with less than 5k miles.
Timing belt
Timing belt tensioner
Oil Pan
As I mentioned above the engine comes complete with everything you need, minus the compression.
SI transmission
Driver and passenger side axles
D16A6 1.6 liter sohc engine
Distributor
Starter
Alternator
Also some extra engine mounts if you need them
$350..The engine is in Fresno and is ready to be picked up
Tenzo Sinko (Mugen RNR replicas).
15x6.5 +35 offset
PCD= 4x100 and 4x114.3
POWDER COATED FLAT BLACK with red lip.
NO CURB rashes, all straight, pretty much these wheels are cherry.
SET (x 4 rims)
no center caps
Tires:
4 Falken Ziex 512's
Does have camber wear
Good to drive on, will need new tires soon.
Pick it up for $475 obo (trades welcomed). I'm in San Jose/Bay Area it can also be picked up at Fresno
I have a few CS Type Air Freshner refills for CS-X3 in Squash scent. These are authentic refills that are made in Japan. $7 a piece picked up or $65 for a box.
Eastwood fender roller for rent.
Rental cost will be $50. You will have to pick up the tool. I will not deliver. Again I’m in San Jose/Bay Area and Fresno.
The rental cost includes the fender rolling tool and a heat gun. It’s a two-day rental (i.e. rent on Monday and it will be due on Wednesday), a $10/day fee will be charged until it’s returned to me.
A $250 refundable deposit will be required when the tool(s) is rented out. I will refund the $250 when the tool(s) is returned in the condition you received it.
If there are signs of damage done to the equipment, you will pay for repair/replacement of tool(s) damaged.
PM me if you want to rent the tool.
Warning… I’m not liable for any damage done to your vehicle as a result of YOU using this tool. If you mess up, it’s your bad. (If you have an older car or if you do not heat up the fender enough, some paint chipping may occur.)
Modified by ijustchillin at 10:44 AM 7/4/2007
Modified by ijustchillin at 10:45 AM 7/4/2007
Timing belt
Oil Pan
SI transmission
Distributor
Starter
Alternator
15x6.5 +35 offset
SET (x 4 rims)
no center caps
Tires:
4 Falken Ziex 512's
BerniniCaCO3
Honda Civic (2001 - 2005)
Jun 8, 2014 06:15 AM
Sucreem
Jun 27, 2013 03:09 PM
