DC5 Brembo Conversion
ok so im buying a DC5 Brembo Conversion off my buddy its type r shocks and springs(which i dont need) hubs and spindles with rotors and BREMBO calipers, aluminum lower control arms, and struts
my question is will i need type r sway bars and endlinks or will i be ok the only other thing i know i will need is axles
you'll need the front DC5-R sway bar ...
As far as axles go ... I've been running Type S axles for almost a year with a couple track events on them with my swap and have had no problem. I'm sure some people will say that you must have the Type R axles since they are a little bit longer, but the Type S axles will work.
cool thanks i guess im gonna buy they sway bar first and buy the axles later when i get some more cash also do you think i could sell my dc5 five lug conversion? how much do they go for?
you should def be able to sell your stock DC5 5-lug stuff with little problem ... I'm sure there are some 4-lug EP3 owners out there looking to do the conversion ... not sure what the entire conversion goes for (def not as much as the brembo package, but you should get something for it) search for previous or current 5-lug sales to give yourself an idea.
Good Luck!
Good Luck!
so how long have you had your brembo conversion? and also what kind of rotors do you buy? i already know what kind of pads to buy but im not sure on the rotors
