my new password gsr motor swap has no vtec???!!?? :(
my new swap has no vtec.. the selenoid is good and, plenty of oil and the ecu is good..still no vtec... im buggin out.. someone asked if my oil pan was dented and if so it could be a factor.. turns out my oil pan has a nice dent in it.. anyone have any input for me???
that info you were told about the dented oil pan means the pickup is affected and oil pressure is not as high as it should be which in turn doesnt allow vtec to engage.
VSS works fine?
You're sure you have no codes?
VSS works fine?
