At least I'm not spoiled!
Old Jun 6, 2007 | 08:15 PM
tehpr3chr's Avatar
Default At least I'm not spoiled!
I finished wiring and everything for my obd1 b16a into my 97 civic coupe tonight. Went to crank the engine and the fuel filter starts losing fuel (not tight enough). I tell my grandfather "well there it starts". We tighten the fuel filter and turn the engine over again. The engine cranks and idles decent with a CEL being thrown. After idling for a few seconds, the fuel pressure regulator blows on the bottom side and starts spraying. It wasn't a violent blow or anything, just kinda a fast leak. I'm picking up a new regulator Friday since I have a funeral to attend tomorrow, but I think this swap will end up nicely, with only a few issues. I saw that I need a VTEC pressure switch sensor wired in, but I have an EX civic, so maybe I won't need this. We'll see...I didn't read into this swap as much as I should, but I do know my way around Honda engines and swaps a little. I'll try and update later.
Old Jun 6, 2007 | 08:16 PM
ke98248's Avatar
Default Re: At least I'm not spoiled! (tehpr3chr)
Is there a tech. question in there somewhere?
Old Jun 6, 2007 | 08:17 PM
civicslayrx's Avatar
Default Re: At least I'm not spoiled! (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Is there a tech. question in there somewhere?</TD></TR></TABLE>
not that i saw.
Old Jun 6, 2007 | 08:18 PM
tehpr3chr's Avatar
well if you want one, here goes. Do I need to wire in the VTEC pressure switch? where is it located?
Ride Da Fire
May 25, 2013 07:19 PM
kimoDA
Jun 21, 2006 09:55 AM
goldenvizion
12
Nov 1, 2005 09:12 AM
HBP.EH2
Jul 4, 2005 09:40 PM
ThatRicerDaniel
Jan 28, 2003 04:08 PM
