94 Civic DX A/C...
Old Jun 6, 2007 | 07:39 PM
bale43kn's Avatar
Default 94 Civic DX A/C...
My A/C doesn't blow cold air at all. The heater works fine though. I really need it for this heat. x_x
Do you think I just need a recharge?
Do you think I need something else?
How much am I going to be spending on this?
Thanks.
Old Jun 6, 2007 | 09:04 PM
Interlinker's Avatar
Default Re: 94 Civic DX A/C... (bale43kn)
Depends if there is a leak in the system. PLaces will NOT recharge until you get the leaks fixed. That costs BIG bucks depending on where the leaks are. Most recharges are 30 to 40 bucks.
Old Jun 6, 2007 | 09:27 PM
ke98248's Avatar
Default Re: 94 Civic DX A/C... (Interlinker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Interlinker &raquo;</TD></TR><TR><TD CLASS="quote">Depends if there is a leak in the system. PLaces will NOT recharge until you get the leaks fixed. That costs BIG bucks depending on where the leaks are. Most recharges are 30 to 40 bucks.</TD></TR></TABLE>Yep. Go to autozone ftw
Old Jun 6, 2007 | 09:29 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: 94 Civic DX A/C... (ke98248)
I say try the autozone can. It's like $10-15 and it will at least work temporarily. If it only works for a short while you have an a/c system leak.
You can buy chemicals to locate the leak, though stock a/c systems will continuously lose freon over time. It's a small amount, but over a 14 year period of time it can happen.
Recharge it yourself, it's easy.
Old Jun 6, 2007 | 10:02 PM
chrisw85's Avatar
Most common leaks are from the schrader valves in the low/high side connection fittings, and also the compressor.
Of course, with the condensor being right there in the front, it could have a hole in it from a rock hitting it. I doubt the evaporator in the car has a hole in it.
Old Jun 6, 2007 | 11:28 PM
bale43kn's Avatar
Default Re: (chrisw85)
Okay thanks guys, I'll try the autozone thing tomorrow.
$30-$40 sounds just fine
Old Jun 8, 2007 | 06:28 PM
bale43kn's Avatar
Default Re: (bale43kn)
I did just that. Went to autozone and bought a can of refrigerant. A/C works fine now BUT... when i use it, my car seems to have a lot less power. It even cuts off when i put it in gear and try to accelerate.(sometimes)
This cant be normal, can it?
Old Jun 9, 2007 | 07:51 PM
bale43kn's Avatar
BUMP
Old Jun 10, 2007 | 08:52 AM
erixxxhouse's Avatar
If you are on a D then yea. U lose alot of power when the Ac is on. Try removing the belt and check to make sure that all the pullys and the compressor spin freely.
Get a B series swap and you will be good.
Old Jun 10, 2007 | 09:00 AM
Ek Forever y0!
Default Re: (erixxxhouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erixxxhouse &raquo;</TD></TR><TR><TD CLASS="quote">If you are on a D then yea. U lose alot of power when the Ac is on. Try removing the belt and check to make sure that all the pullys and the compressor spin freely.
Get a B series swap and you will be good.</TD></TR></TABLE>
So a b-series swap is his solution to fixing his ac being warm problem.
He didn't seem concerned with the 2hp loss from having ac.
It takes the same power from a b-series or a d-series to operate a/c in any car. It's just less noticeable.
madhatter4119
Jun 29, 2016 11:18 AM
slammed94ferio
Jun 20, 2007 12:39 PM
urname7698
Honda Civic (2006 - 2015)
11
Oct 2, 2006 02:58 PM
cats_on_ice
May 6, 2006 05:59 AM
mjf1886
Aug 2, 2005 08:36 AM
