alot of oem and aftermarket d and b series stuff evo 8 turbo and more
Old Jun 6, 2007 | 05:29 PM
aarontrini85's Avatar
Default alot of oem and aftermarket d and b series stuff evo 8 turbo and more
i have some stuff im looking to sell im open to offers right now
stock b16 exhaust manifold obd0 with sensors still in it
stock obd1 ls intake manofold all sensors still there but no t/b
stock b18b needs to be cleaned up on the bottom end and the top end is take all apart all though all parts are there valves will need to be replaced
b18c type r stock header 2.5" outlet with b16 heat shield on it fits fine although 2 bolts dont line up
91 crx tail lights good conditon (includes center)
89 crx taillights left one is cracked every thing else is fine (includes center)
obd0 integra ls harness
pm6 ecu
td05hr 16g with flange and o2 housing
turbo concepts waste gate 38mm wastegate with 1 bar tial spring in it
t3 turbo manifold looks like this but not cheap ssauto chrome crap its beffy and well braced
oem starter should work on any b or d there not obd specific and the mounts are all the same on the trans
oem fan switch with housing for a d series (off a y8)
*** loads of obd0 and obd1 injectors
megan front lower tie bar silver
passanger side d series cable trans motor mount
passanger side b series cable trans motor mount
driver side b series mount obd0
also the bracket for an obd1 driver side mount (the part that goes on the block)
crx si cluster just needs new needle for the gas portion
oem d series radiator hoses for an ef might fit an eg to i dont know
oem radius arms with brand new prothane bushings installed never driven on after the bushings were put on
passanger side del sol door some scratches its black the glass is good and the door panel is good
obd0 ac compressor off a b16
obd0 power steering off a b16
there might be more but i have to check
Modified by aarontrini85 at 5:50 AM 6/7/2007
Old Jun 7, 2007 | 04:56 AM
Default Re: alot of oem and aftermarket d and b series stuff evo 8 turbo and more (aarontrini85)
buy my **** help me get an edelbrock header and some itb's damnit
Old Jun 7, 2007 | 07:26 AM
dont be afraid to low ball me
Old Jun 9, 2007 | 05:41 PM
bump i need an obd1 dizzy so if you want any thing here and have one let me know and well trade
WFboostinEK
Jul 10, 2008 04:09 AM
wickedEFguy
Dec 18, 2007 02:03 PM
wickedEFguy
Dec 18, 2007 01:59 PM
HighRevn
Dec 7, 2007 02:26 PM
Will_H
May 27, 2005 02:41 PM
