fog light ?
ok i put in oem fogs and the only turn on with the headlights and when i turn the highs on the fogs go off. i want to be able to make the fogs go on by themselves without the headlights. is this possable . if so how?
Run the blue wire from the fog light switch to power when the key is on. If you run it from constant power then the fogs will stay on whenever the fog sw. is on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">haha just be glad that they actually turn on... i'm stuck with non functional ebay foggies </TD></TR></TABLE>
Lets fix your fogs. What is going on with yours?
Year and trim.....
Year and trim.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikelax125 »</TD></TR><TR><TD CLASS="quote">ok i put in oem fogs and the only turn on with the headlights and when i turn the highs on the fogs go off. i want to be able to make the fogs go on by themselves without the headlights. is this possable . if so how?</TD></TR></TABLE>
Splice them into your peanut bulbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiveten »</TD></TR><TR><TD CLASS="quote">I have a set for sale. 03 4dr.....</TD></TR></TABLE>
Why would he buy something he already has?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiveten »</TD></TR><TR><TD CLASS="quote">I'm just putting it out there. For everyone....</TD></TR></TABLE>
There's a for sale thread for that.
my fogs turn on only while my running lights are on.... also if i turn my headlights on.. dont know how my cousin wired them but ill let you know if u still need help
no instructions came with them. used handa and some other site which was for a robear kit... looked pretty much like a ebay kit.
what do you mean by switching the relays? the fog harness is a no brainer. the sub harness as well. the switch harness only has a 1 pin and a 4 pin left open after the switch and relay are installed... i've grounded everything... the only problem is that i'm not getting any power cause of the plugs they provided. check your pm. there is another thread with this subject. posted up pics
