What kind of engine has the same clutch as the F20Z1?
Old Jun 6, 2007 | 01:55 PM
RubenPrelude's Avatar
Default What kind of engine has the same clutch as the F20Z1?
I'm from the Netherlands, so sorry for my bad english, and I have a boosted F20Z1(Accord '93)But I couldn't find a reinforced clutch for it. I heard rumours that the F22A has the same clutch, is that true? Does anyone know what kind of clutch I can use?Thanks in advance!
Old Jun 6, 2007 | 02:42 PM
pinecone's Avatar
Default Re: What kind of engine has the same clutch as the F20Z1? (RubenPrelude)
Any H/F series clutch will work.
Old Jun 6, 2007 | 10:41 PM
So you mean, that I could buy a clutch for (example)a F22A and could mount it right on my engine?
Old Jun 7, 2007 | 12:01 AM
pinecone's Avatar
Default Re: (RubenPrelude)
Yes, clutch and flywheel will work.
Old Jun 7, 2007 | 01:15 AM
That's good news!But why is it then, that all producers of aftermarket clutches, make a clutch fo each type of Honda H and F serie?
Old Jun 7, 2007 | 10:30 AM
Hawkze_2.3's Avatar
Actually most clutches and flywheels say for Honda H/F series engines. The S2000 F-series are probably different though...
Your English is actually pretty good
Old Jun 7, 2007 | 11:02 AM
prelittlelude's Avatar
any h or F except the s2000 clutch. if your unsure just get a h22a1 clucth it will work no problem. all have same bolt pattern and flywheel
ActionClutch
Sep 22, 2014 10:56 AM
F20Cdriver
Honda S2000
Oct 8, 2007 03:35 PM
Odessa
Sep 7, 2003 08:01 PM
ALF
Nov 30, 2001 09:58 PM
lozersk8er
Oct 11, 2001 05:45 PM
