edelbrock victor x IM help install!
Old Jun 6, 2007 | 12:45 PM
egzo04's Avatar
Default edelbrock victor x IM help install!
i got a b18c and im putting on a victor x IM, what do i do with the Intake air bypass control diaphragm valve on the stock IM?, i looked everywhere, and i dont see a way to take the spring off and install it on the new IM, do i just cap the vac line going to the IAB vacuum tank? or do i just tap it onto one of the holes on the new IM for vac lines.
Old Jun 8, 2007 | 03:25 PM
Beyond_Redline's Avatar
Default Re: edelbrock victor x IM help install! (egzo04)
The Victor X is a single stage manifold optimized for high rpm use. It doesn't have any provsions for the secondary butterflies. All of the associated equipment should be removed.
Old Jun 8, 2007 | 03:33 PM
Dartanian's Avatar
What is your setup that you need such a huge intake manifold?
If this is a stock motor, you will hate life with that thing on there.
Old Jun 8, 2007 | 07:22 PM
Muckman's Avatar
Moderator in Chief
haha you were trying to install the IAB solenoid onto your Victor X manifold? Did you even research this manifold before you bought it?
Old Jun 8, 2007 | 09:21 PM
1.8L_allmotormilitia's Avatar
Default Re: edelbrock victor x IM help install! (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">haha you were trying to install the IAB solenoid onto your Victor X manifold? Did you even research this manifold before you bought it?</TD></TR></TABLE>
perseverance
Oct 31, 2006 10:15 PM
tr0n9h
Nov 30, 2005 11:04 AM
RTW DC2R
Jan 21, 2005 04:36 PM
Geeq
Dec 27, 2004 11:02 PM
Two_K Si
Nov 3, 2004 06:35 PM
