programming a keyless entry keypad keychain
Old Jun 6, 2007 | 10:50 AM
04Si's Avatar
Default programming a keyless entry keypad keychain
my friend has an remote for the locks/alarm which is exactly the same as mine for my ep3, is there a way to re-program his remote to work with my car? when i brought the car it didnt come with a spare so it'd be great to have one....i know there's a sequence of events to reprogram, thanks!
Old Jun 6, 2007 | 01:35 PM
04Si's Avatar
Default Re: programming a keyless entry keypad keychain (04Si)
well i did my hw, below are the instructions in case anyone else is interested, if its not on the forums already:
Programming the Transmitter
NOTES :
^ The system accepts up to three transmitters. The transmitter codes are stored in a stacking-type memory. If a fourth transmitter code is programmed, the code for the first transmitter is erased.
^ Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all of the transmitters once you are in the programming mode.
^ You must complete steps 1-6 within 4 seconds of the previous step to keep the system from exiting the programming mode.
1. Turn the ignition switch to ON (II).
2. Press the "Lock" or "Unlock" button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the "Lock" or "Unlock" button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the "Lock" or "Unlock" button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
civicsracer
18
Oct 16, 2006 08:28 AM
SC0TT
Audio / Security / Video
Feb 19, 2005 07:58 PM
EricUSC
Jan 13, 2004 06:15 PM
georgeda
Mar 12, 2003 09:57 AM
doe
10
Sep 10, 2002 12:40 PM
