seat belt lights come on when brake pedal is pressed...
Old Jun 5, 2007 | 07:48 PM
Ron Burgandy's Avatar
Default seat belt lights come on when brake pedal is pressed...
I there, so I just purchased a 1990 crx hf....with some goodies. This is my 4th honda but this is a new probleme to me. Here's whats happening:
When I press on the brake pedal the seat belt lights come on the dash and the unit on the floor starts to beep....it goes away imediatley after I release the brake. I was told that it might be a bad ground, but I'm really sure where to start. Any Ideas? Also, the rear brake light doesnt come on when brake is pressed.
Old Jun 5, 2007 | 07:54 PM
Tippyman's Avatar
Default Re: seat belt lights come on when brake pedal is pressed... (Ron Burgandy)
Well, obviously it's a wiring issue. The only thing I can think to do is to trace the wiring for the brake and seatbelts to see if they cross or are grounding or shorting out somewhere.
Old Jun 5, 2007 | 08:29 PM
mkcivic's Avatar
i had the same problem on an 88 and came to find out that the jackass that had it before me rigged the wiring i say f'it just unplug the switch unless you absolutely feel the need to have a reminder to put your belt on
Old Jun 5, 2007 | 08:32 PM
Tippyman's Avatar
Default Re: (mkcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkcivic &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem on an 88 and came to find out that the jackass that had it before me rigged the wiring i say f'it just unplug the switch unless you absolutely feel the need to have a reminder to put your belt on</TD></TR></TABLE>
I unplugged mine day 1.
Old Jun 5, 2007 | 08:43 PM
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
I unplugged mine day 1.</TD></TR></TABLE>
Does this make the control unit beep non-stop?
Also, the only thing I really even car about is that my brake lights don't come on.
Old Jun 5, 2007 | 08:45 PM
turbostd's Avatar
The fuse for the brake lites is out.
Old Jun 5, 2007 | 10:21 PM
Default Re: (turbostd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbostd &raquo;</TD></TR><TR><TD CLASS="quote">The fuse for the brake lites is out.</TD></TR></TABLE>
Is that just a guess?....because you said that so matter of factly. The brake light fuse is not the issue.
Old Jun 5, 2007 | 10:23 PM
turbostd's Avatar
Default Re: (Ron Burgandy)
thats what was wrong with my car when it did that. the buzzer means your brake lites arnt working so it must be in the wiring somewhere if its not the fuse.
https://honda-tech.com/zerothread?id=1699636
Old Jun 5, 2007 | 11:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbostd &raquo;</TD></TR><TR><TD CLASS="quote">thats what was wrong with my car when it did that. the buzzer means your brake lites arnt working so it must be in the wiring somewhere if its not the fuse.
https://honda-tech.com/zerothread?id=1699636</TD></TR></TABLE>
That is a very helpful link....I havn't checked that fuse yet, and from the looks of it I'm sure that is the problem.
thanks and I'll let you know
Old Jun 6, 2007 | 04:21 AM
Cory man's Avatar
Its the stop/horn fuse located in the underhood fusebox. IIRC its a 20a fuse. I doubt your horn works either. hth
Old Jun 7, 2007 | 12:49 AM
Problem solved! THANKS everyone for your wisdom....it was the stop/horn fuse under the hood.
Old Jun 7, 2007 | 04:25 AM
slywfbpsi's Avatar
Default Re: (Cory man)
I had the same problem, but everytime I changed out the fuse and hit the brakes the fuse would blow again. Come to find out there was a loose wire touching my chassis., fixed that, no more issues
Old Jun 7, 2007 | 09:54 AM
Default Re: (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem, but everytime I changed out the fuse and hit the brakes the fuse would blow again. Come to find out there was a loose wire touching my chassis., fixed that, no more issues</TD></TR></TABLE>
good to know, I'll look out for that.
gsxr-t-bag600
Dec 27, 2011 09:51 PM
dougb77
May 8, 2006 02:20 PM
S13 slide
Dec 9, 2002 06:34 AM
Agent Daimon
11
Jul 19, 2002 08:39 PM
