TOKICO HP
Old Jun 5, 2007 | 07:30 PM
jweeks's Avatar
Default TOKICO HP
tokico hp shocks/struts any good?
Old Jun 5, 2007 | 09:37 PM
FotoGenetix's Avatar
Default Re: TOKICO HP (jweeks)
for an oem replacement strut thats a little firmer then stock, yes they do the job just fine. there are some here that have had the shock blown due to excessive lowering.
if you want something for a decent street ride then these work just fine. i just wouldnt get slip on coil overs with them. a decent spring that drops 1.5-2.0 should have no problem.
again these are for daily driver, not for track use.
Modified by FotoGenetix at 12:33 PM 6/6/2007
Old Jun 5, 2007 | 11:12 PM
.Manny.'s Avatar
Touching My Member
Default Re: TOKICO HP (FotoGenetix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FotoGenetix &raquo;</TD></TR><TR><TD CLASS="quote">for an oem replacement strut thats a little firmer then stock, yes they do the job just fine. there are some here that have had the shock blown do to excessive lowering.</TD></TR></TABLE>
very true.
my question to you is... what are you looking for in your suspension set up?
answer that one and i'm sure a lot of us here will be able to help you out a bit more.
Old Jun 5, 2007 | 11:26 PM
crxnj's Avatar
Default Re: TOKICO HP (.Manny.)
Yeah these shocks are good stock replacment,,or with the use of a slightly stiffer and lower spring..
Old Jun 6, 2007 | 09:11 AM
wiZCo's Avatar
Stouts 'n' Scotch
This is good info. I use the HP struts with the Tokico "Red" Springs. The car is lowered about 1.5" or so and handles well, it's just a little stiffer and bouncier than the stock shocks. I too would not recommend a slip-on coilover or a drop beyond 2 inches if you're going to use them.
johnickys ek
Feb 12, 2008 04:32 AM
RighteousRyano
Suspension & Brakes
Apr 2, 2007 07:38 PM
skeelo
Suspension & Brakes
Nov 7, 2005 09:55 AM
Generic User Name
Jan 1, 2005 05:31 PM
01SSAP1
Dec 17, 2004 06:37 PM
