ITR Oil Leak question?
Old Jun 5, 2007 | 07:19 PM
boostitr808's Avatar
Default ITR Oil Leak question?
I'm a noob at this so bare with me.
Well i just got back my B18C5 block from RS Machines. Pretty much built the bottom end. (Bored out 82mm, CP pistons 9:5 comp, RS Sleeves, Micro Polish Crank, Knife Edge Crank etc...)
Well i assembled the head together ARP head studs (To spec) Cam Caps (To Spec) etc. As I cranked for oil pressure i noticed that it was leaking oil from the corner of the distributor side of the head. I was wondering what would be the problem of it? I'm running a cometic head gasket .030 thickness.
I also was wondering if i should've put the gasket on with the dowels, then the actual head itself, before installing the head studs than gasket, than the head itself before i torqued everything down.
Could it be the gasket, or could it be the head didn't sit right?
Any answers.
Old Jun 5, 2007 | 07:24 PM
GO-FIGHT-KILL's Avatar
Did you have the head resurfaced?
Is the oil leaking FROM the headgasket?
Old Jun 5, 2007 | 07:50 PM
Default Re: (GO-FIGHT-KILL)
Yes I did,
I asked the machine shop to resurface as little as possible.
Its pretty much a slow leak from idle then when pressure is in it leaks a lot.
So it might be the gasket itself because thats the only area that its leaking from. Thats what I think.
mijos
Sep 5, 2020 05:56 PM
R6Elmo
Nov 13, 2003 04:47 PM
InfamousRS
Jun 2, 2002 08:21 AM
