clutch ? for the pros
Old Jun 4, 2002 | 02:42 AM
EF'n's Avatar
Default clutch ? for the pros
i look at the exedy organic and the cm stage 1 and they look like oem, how are they any better than if i just get a new stock one. i am just looking to justify the $100 more that they cost over a stock one.
Old Jun 4, 2002 | 05:52 AM
BlazinSI's Avatar
Default Re: clutch ? for the pros (revhardracing)
go with a stage-3 CM, I got the stage-3 with the alluminum flywheel and it was only like 300 more than I would of paid for stock....
Old Jun 4, 2002 | 08:18 AM
wronghand's Avatar
The exedy organinc and cm stage 1 are very comparable clutches. They both have stock feel. The difference is they both have roughly 50% more holding power than stock. So unless you have some major mods (turbo, nitrous, sc) you probably won't really need the extra holding power. That being said, if you ever plan to add any of the above why not spend the extra cash now rather than later.
Also, if you plan on doing any auto-x or drag racing it probably wouldn't be a bad idea to upgrade the clutch.
Old Jun 4, 2002 | 03:27 PM
EF'n's Avatar
Default Re: clutch ? for the pros (wronghand)
i do auto-x and i do plan on doing a couple of passes at a drag strip with a 50 shot of happy gas. my ? is, are the pp different than stock or is it just the material used on the disk. i would like averyones opinion on what they like and dont like about there current set up with flywheel/clutch combos. it looks like i am going to use a 2001 type r flywheel and most likly the cm stage 3, just want to do my research of actual users first.
preludeboybmw
Nov 13, 2007 06:27 PM
SpeedoKing
Apr 23, 2007 12:17 AM
SpankyG
Dec 5, 2005 01:25 PM
airikkCRX
Jun 12, 2005 07:41 PM
Nightscape
May 17, 2004 01:17 AM
