Seafoam doesn't work.
Seafoam doesn't work. STOP using that. If you want or need something
that really work, you should try GM Top Engine Cleaner Part #1052626.
It's alot stronger, and the best product sofar that really clean the carbon buildup in just minutes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magic Wheels »</TD></TR><TR><TD CLASS="quote">Seafoam doesn't work. STOP using that. If you want or need something
It's alot stronger, and the best product sofar that really clean the carbon buildup in just minutes.</TD></TR></TABLE>
I disagree that Seafoam doesn't work. Do you have anything to back up this statement before preaching about it?
Munkyw3rkz.webs.com
yes it works, but it works so well that on motors with higher milage tend to start burning oil because the carbon build up was helping to seal the rings....
