both key fabs not working....how to reset
when i got my s2k both of the fabs didnt work. the guy i bought it from had it in the shop getin the fender painted due to a accident and said it didnt work when he left...maybe they reset the battery??? anyway i tried reseting it following the directions in my owners manual but it didnt work..maybe i was doin somethin wrong..any ideas?
Search on http://www.s2ki.net for this. There are a few articles on syncing the remotes.
Replace the batteries in the remotes as well, and if all else fails, is it under warranty?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtzx9r »</TD></TR><TR><TD CLASS="quote">Search on http://www.s2ki.net for this. There are a few articles on syncing the remotes.
Replace the batteries in the remotes as well, and if all else fails, is it under warranty?</TD></TR></TABLE>
He did post on http://www.s2ki.com and they said the issue was he's using a key FAB instead of a FOB.
He also tried changing the batteries as well.
To the OP, I thought you said you were going to the dealer for this?
He also tried changing the batteries as well.To the OP, I thought you said you were going to the dealer for this?
yah i went to honda today and got a tech to try to set the FOB and it didnt work so he said it might be the transmitter which cost 700 bucks to replace so yea f that..im gona check the fuse panel when i get off work and c if a fuse is blown
1329itr00
Jul 20, 2005 09:46 PM
