zc info?
Old Jun 4, 2002 | 02:14 AM
86CRXSi's Avatar
Default zc info?
how difficult is zc swap for 1st gen crx? how do you get parts for it, cams, headers, cam gears, intakes, ect..... does it have a us equivalent?
wut is a good source? And most important do they come with a/c, will it swap, and will it fit? Any and all info please..........thanks.......
Old Jun 4, 2002 | 03:15 AM
keithv's Avatar
Default Re: zc info? (86CRXSi)
the zc swap doesn't bolt right in to a 1st gen crx. your better off going with a 1st gen teg motor which is pretty close to the usdm equivalent of the zc.
a/c will be tight from looking at my friend's swap. but it will bolt right in.
Old Jun 4, 2002 | 07:58 AM
86CRXSi's Avatar
Default Re: zc info? (breaka_1_9)
don't know "teg" motor..........from wut, stock hp, how complex a swap????
Old Jun 4, 2002 | 08:10 AM
wronghand's Avatar
He is referring to the 86-89 integra motor. This is the D16A1. It is very similar to the blacktop ZC. It is a dohc motor and produces roughly 115 hp. It is all but a direct bolt in. The only modification required is notching one of the motor mounts. That motor with a set of ZC cams should put you close to the blacktop's output. Just remember that Honda changed things slightly from 87 to 88. That being said you would need the 86 or 87 integra ecu for that motor.
I hope this helps.
Hayasa15's Avatar
Try a search.
[Modified by Hayasa15, 12:11 PM 6/4/2002]
temporarysuicide
Oct 31, 2006 12:48 PM
djphonics
Apr 18, 2006 07:28 AM
staticrex
Aug 24, 2004 10:35 AM
russian_racer
Sep 20, 2002 07:15 PM
v-tec crx
Dec 5, 2001 02:36 PM
