Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How do you change the head light bulbs?
Old Jun 5, 2007 | 01:52 PM
koldfeet's Avatar
Default How do you change the head light bulbs?
2007 Honda Civic Si sedan
Im trying to replace a faulty lightbulb on the front right headlight. I can see the bulb from under the hood, but there's just no way I can fit my hand in there. How do you remove it properly?
thanks
Old Jun 5, 2007 | 01:55 PM
FBPSidan's Avatar
Default Re: How do you change the head light bulbs? (koldfeet)
Turn wheels all the way.. reach in through fenderliner.. takes less than 5 minutes
Old Jun 5, 2007 | 02:08 PM
koldfeet's Avatar
Default Re: How do you change the head light bulbs? (FBPSidan)
thanks!
Old Jun 5, 2007 | 05:59 PM
FA_King's Avatar
I unbolted that thingy and squeezed my hand through. I didn't remove it but just let it flex enough to reach the bulb. I did it, you can do it also.
Old Aug 3, 2007 | 11:53 PM
Xenon911's Avatar
Banned
2 differnt ways
1. Take the head lamp out ( Very Very Very Very Hard )
2. From under the fender, turn the wheel all the way to one side ( better )
Old Aug 4, 2007 | 09:48 AM
originalg00kster's Avatar
Default Re: How do you change the head light bulbs? (Xenon911)
take out your coolant resevoir...and stick your hand down there.
Old Dec 30, 2010 | 12:38 PM
FuZioNxMaxBoost's Avatar
Bump for any new "easier" ways
Old Dec 31, 2010 | 07:26 AM
joshsayswhatt's Avatar
is it a high or low beam?
high beam- just reach in through the top (for drivers side you have to remove the reservoir by pulling up), remove the plug, then twist the bulb (reverse for install)
low beam- is the difficult, turn steering wheel to the right for driver side, left for passenger side, pull back the wheel well shield, reach in and remove the plug, then twist the bulb (reverse for install)
Old Dec 31, 2010 | 09:13 AM
randomtask77's Avatar
Get someone else to do it. :p
Old Jan 13, 2011 | 10:33 PM
Uncle_Ben's Avatar
Not going to lie, the headlight design is pretty stupid. On my old WRX everything was accessible straight from the engine bay with no obstructions. When I changed my lowbeams I removed the washer tank AND the ABS unit and it didn't really help. Needless to say I'll try the wheel well method next time, do you have to remove clips to get behind the fender liner?
SteveP
Nov 26, 2017 01:19 PM
Snowsrfr
Mar 4, 2010 10:17 AM
k3ntegra
Oct 9, 2009 10:16 AM
TurismoDreamin
Aug 17, 2005 01:14 AM
Mr.Speed
May 1, 2005 12:19 PM
