high idle and overheating after new timing belt and water pump
Old Jun 5, 2007 | 11:42 AM
rodvang's Avatar
Default high idle and overheating after new timing belt and water pump
I have a lsvtec swap and installed a new gsr waterpump with gsr timing belt and my idle is now high (around 2k) and it overheats. It was overheating a little before because the radiator fan doesnt always kick on like its suppose to but it seems worse now..could it have just been a bad install on the water pump? How do you check to see if it is working properly? And for the idle..do i just need to retime it?
Old Jun 5, 2007 | 12:21 PM
b18b1turbo's Avatar
Default Re: high idle and overheating after new timing belt and water pump (rodvang)
did you replace your thermostat too and did you adjust your throttle cable?that might be why your revving high.get a electric fan.hope i help out a little.
Old Jun 5, 2007 | 12:33 PM
rodvang's Avatar
Default Re: high idle and overheating after new timing belt and water pump (b18b1turbo)
throttle cable needs to be adjusted if i didnt touch it? I'll have to check on that. Also I didnt get a new thermostat yet but im gonna do that also. Anyone else have anything else I should check/do?
Old Jun 5, 2007 | 07:17 PM
rodvang's Avatar
bump
Old Jun 6, 2007 | 01:45 PM
rodvang's Avatar
up for some more input
Old Jun 6, 2007 | 01:58 PM
BubblegumTate's Avatar
Did you evacuate all of the air out of the cooling system after you refilled it? High idle and overheating are both symptoms of low coolant or air in the system.
Old Jun 6, 2007 | 02:12 PM
rodvang's Avatar
Default Re: high idle and overheating after new timing belt and water pump (BubblegumTate)
did a cold start with full system and burped it as normal. The coolant would get extremely hot with the cap off though and it was start overfilling and blew up like a volcano.
Old Jun 6, 2007 | 02:30 PM
97civicdx's Avatar
Its gonna do that until all the air is out of the system. Dont rev motor then. All the air has to be out...
Siegs
May 5, 2014 11:16 AM
Tombomb661
Jul 26, 2011 10:07 PM
kornerk12
Apr 13, 2009 05:33 PM
tub_sephiroth
Jan 20, 2003 05:58 AM
