Honda S2000 Honda S2000
RACE GAS (VP RACING)
Old Jun 5, 2007 | 10:48 AM
patricks2000's Avatar
Default RACE GAS (VP RACING)
what do you thing bout running 100 octain or so in an s2000. with or without a cateletic converter?
Old Jun 5, 2007 | 10:56 AM
LAS2K's Avatar
Default Re: RACE GAS (patricks2000)
what for? you're just wasting money unless you're FI and/or tuned for it.
Old Jun 5, 2007 | 11:18 AM
Default Re: RACE GAS (LAS2K)
well im not talking like a full tank. just a couple gallons. just for specific races. you think it wouls be usefull... or do you think it would harm something in the motor?
Old Jun 5, 2007 | 11:25 AM
not talking a whole tank of it. just a couple gallons for specific races. will it harm the motor at all?
Old Jun 5, 2007 | 11:29 AM
Mr. Projekt's Avatar
* B A N N E D *
Harm? You must be crazy. I run nothing but 100 octane at the tracks, with no cat. Smells like sex and candy.
LAS2K's Avatar
no it wont hurt.
Old Jun 5, 2007 | 11:41 AM
SilverDc2's Avatar
i heard it makes your vtec in reverse a lot smoother with 100 oct,
Old Jun 5, 2007 | 12:06 PM
Default Re: RACE GAS (Mr. Projekt)
how much of a difference do you think it makes?
Old Jun 5, 2007 | 12:12 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: RACE GAS (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">i heard it makes your vtec in reverse a lot smoother with 100 oct, </TD></TR></TABLE>
hahahah
but seriously, u can run it but to get the most out of it u need to be tuned so you can take advantage of the ign. timing.
remember if you run race gas you will damage your cat. run 76 pump 100 and you will be kool but more then that then your car will be in trouble
Old Jun 5, 2007 | 01:43 PM
wrice4's Avatar
i run premium....lol
Old Jun 5, 2007 | 02:37 PM
Sean Juan's Avatar
Default Re: (wrice4)
I was on empty so I ran a gallon of 110 one time just to see. It was a noticeable difference once it got going thru the fuel lines. Just don't continuously run it or else you'll need to replace your o2 sensors.
Old Jun 6, 2007 | 10:07 AM
cmrs2k's Avatar
Default Re: (Sean Juan)
octane is just a detonation safeguard, its not a power adder. Using it isn't going to help power unless you can tune and adjust timing to get closer to that "knock" range. If you use too high octane for too long, you can wash out your rings but thats a severe case before it would happen.
I suspect the butt dyno's that found significant gains with higher octane need some calibration... Maybe on a real hot day when running the car a long time, but without a tune its not doing much if anything.
Using higher octane on many stock tuned cars will actually hurt gas milage and such more than help anything.
Old Jun 6, 2007 | 10:21 AM
Sean Juan's Avatar
Default Re: (cmrs2k)
I disagree with your statement on no gains. I'd love to run a a stock S2000 on the dyno with 93 and then 110.
Old Jun 6, 2007 | 10:48 AM
cmrs2k's Avatar
We'll just have to agree to disagree I guess... lots of people on both sides of this discussion in the past.
I've done a good bit of EFI tuning with N/A and turbo setups, different octanes and even alch injection setups. While I've used higher as a safeguard getting a rough tune, or to squeeze a bit more by adding timing, I've yet to see it add horsepower because the stock box won't add the timing to do it. I'd love to see the direct dyno pulls and it would be fun to do... Just keep in mind you can run the same car on the same dyno, same time, same temps and its gonna boucne around and vari each time.
If a car wasn't running cleanly and was getting knock running 93(which it shouldn't), then it would help. But that just would show that there is something else wrong.
So who is up for an experiement? I'll bring the beer
Old Jun 6, 2007 | 11:59 AM
blkturbos2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean Juan &raquo;</TD></TR><TR><TD CLASS="quote">I disagree with your statement on no gains. I'd love to run a a stock S2000 on the dyno with 93 and then 110.</TD></TR></TABLE>
Are you kidding??? What he said is right. Octane does NOTHING for Hp unless you tune on it. VP makes "VP Import" gas that has oxygen in it to make more power but the high octane will not help with power, **** it may hurt because it is not burning all of the gas each time it sparks. Put it this way, higher the octane harder it is for the gas to start too burn.
Old Jun 6, 2007 | 12:18 PM
Sean Juan's Avatar
Default Re: (blkturbos2k)
That's like saying a FI won't provide gains unless it's tuned. It still will provide some gains, but it's not RIGHT until it's tuned.
Old Jun 6, 2007 | 01:16 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
both are right both are wrong...
yes depending on the motor.. such as a higher comp N/A or boost app.. adding a higher oct. fuel will do a number of things... but it will give it a silght increase , nothing CRAZY but it will give it a kick in the butt..
now being tuned for it to take advantage of the timing(before knock) is of course the way to get the most out of it
Old Jun 6, 2007 | 02:03 PM
Sean Juan's Avatar
Default Re: (S@nt0s)
Werd.
Astig
Jun 8, 2007 12:49 AM
siguy4
16
May 15, 2006 06:46 AM
B-A-N-A-N-A-S
May 20, 2005 11:52 PM
showtymers619
Jul 29, 2004 09:06 PM
SymphonyX
Apr 30, 2003 11:52 AM
