weak d series trans
Old Jun 5, 2007 | 10:25 AM
da9ej1baller's Avatar
Default weak d series trans
alright so im having a problem with d series trans. with my boosted d16z6 motor im only running 7 psi and the input shaft locked up on the first one so i put in a s20 trans in and the same thing is about to happen i lost 2nd gear and it sounds like the input shaft bearings are about to shatter so basicly im tryin to figure out what kind of trans to use or what i can do to make them last longer or stronger any help would be appreciated
Old Jun 5, 2007 | 10:30 AM
EX-T's Avatar
Default Re: weak d series trans (da9ej1baller)
You aren't going to find a D tranny that has a strong ISB. You'll have to do a tranny conversion.
Old Jun 5, 2007 | 11:01 AM
Default Re: weak d series trans (EX-T)
Never heard of anything like this but I just started messing wit d series what I'm guessing is you have 2 get some type of adapter plat and mount a b series trans
hrowell88
Feb 1, 2015 06:07 PM
turboblack2door
Jun 13, 2011 07:17 PM
turboblack2door
Transmission & Drivetrain
Jun 11, 2011 07:57 AM
want2rally
Sep 6, 2005 05:57 PM
