which harness to use for b20 swap
what harness should i use for a b20 swap?? ill be sending the money to someone for the OBD1 LS ecu and im just wondering what is the best harness to use
Josh
Josh
ls or stock one, if your swapping into the del sol i see in the sig, keep your stock one and you will be fine, and u can even use it for vtec later if u plan on swappin on a vtec head
B18C1_CRX
Jul 15, 2006 03:35 PM
af1king1421
Jul 2, 2004 09:13 PM
