Differences between D16A1 and JDM ZC crank?....
The D16A1 crank came in 2 sizes. One has a 22mm snout (86-87) and one has a 24mm snout (88-89). I may have those backwards.
I am not sure which one is in the ZC. If you have access to one, measure it and then you'll know what to hunt for at the junkyard.
Sonny
Sonny
The cams are a different profile, the cam gears on the zc are smaller,the intake manifold flows better on the zc and i belive the valving is different
Cool thank's Sonny.
What part of the crank is The "snout"?
I'll check with some places and see what size the JDM ZC block is. (Anyone?)
Thank's
Thank's
Cool thank's Sonny.
Thank's
Thank's
Sonny
So a 88-89 D16A1 Crank will fit in a JDM ZC correctly?
Wouldn't it also depend on the year of the JDM ZC block?
Well I have come to the conclusion that I'm just going to buy an entire ZC engine. Here's why...
A good block that's never been tampered with(as far as I know)
Low milage internals
All the sensors needed
I get most of my money back parting out the stuff I don't need.
All in all I'm only letting go about a few hundred dollars for the good block I'll have left over.
88-89 are the exact same, i got one and measured out perfectly..
I have a ZC motor, and the crank has some nasty marks on it. But I also have a crank from a 89 teg that is perfect. So I should be good to go on using it right?
