Metallic sparking noise from left wheel O_o
Old Jun 4, 2007 | 11:54 PM
jmai86's Avatar
Default Metallic sparking noise from left wheel O_o
From dead stop to accelerating (only accelerating) up to around 20mph ish, there is an audible metallic sparking noise from the front driver wheel area. It's like an irregular clicking/ clacking/ sparking/ metallic noise.
Bad axle?
Old Jun 5, 2007 | 12:55 AM
TheWalrus's Avatar
could be a bad hub bearing but id say axle too. best way to check is to drive around in circles with the wheel all the way turned at like 15 mph and hit the gas on and off...a bad axle will click only when youre on the gas and go away when you let up
Old Jun 5, 2007 | 04:02 AM
mattsnooz's Avatar
Default Re: (TheWalrus)
are your rotors rusted, or are your pads down to metal?
Old Jun 5, 2007 | 04:54 AM
H22Apowered's Avatar
Default Re: (mattsnooz)
check to make sure the dust cover on the back side of the rotor isnt bent and making contact with it
Old Jun 5, 2007 | 03:57 PM
jmai86's Avatar
Default Re: (H22Apowered)
Thanks for the input
Rotors are fine. I tried bending the dust cover a little and it seems to have reduced the noise a little. I think it may be the source.. because when I change its position, the noises come up in different variations.
hm
dopesk8er87
27
Apr 9, 2013 07:51 PM
SHystrdyGSRtdy
Mar 4, 2013 01:24 PM
jkalex05
Nov 23, 2009 06:52 PM
-faded-
Nov 7, 2007 11:26 AM
