Are all Type R tranny's LSD equipped?
Old Jun 3, 2002 | 10:39 PM
AbaZ's Avatar
Default Are all Type R tranny's LSD equipped?
I found a B18c5 sitting in the corner of our shop shortblock with Tranny. I was curious if these trannys had a factory LSD. Someone said an easy way to find out is just look through the axle hole and if you see a Pin it isnt LSD. This tranny DOES have a pin.. So anyone know?
Its supposivly a JDM tranny.
Thanks
Jeff
Old Jun 3, 2002 | 10:43 PM
Reid's Avatar
Global Moderator
Default Re: Are all Type R tranny's LSD equipped? (AbaZ)
Yes, all ITR trannies have LSD.
Old Jun 3, 2002 | 10:45 PM
Mario's Avatar
LSD check=You should be able to see through the drive/half shaft holes clearly, no obstruction. At least that's the case for oem Honda LSD...not sure about aftermarket though.
Did you check the stamping on the tranny case first?
AbaZ's Avatar
Default Re: Are all Type R tranny's LSD equipped? (Reid)
By any chance do you know the model # of the Type R tranny? I.E S20/L3/YS1/J1/SI etc. etc..
thanks
Old Jun 3, 2002 | 10:47 PM
Reid's Avatar
Global Moderator
Well first of all the shortblock isn't JDM if it says B18C5.
Also if it's a JDM tranny it won't have a designation plate, just bare, unthreaded holes. If there are threaded holes and no plate, then someone has removed the plate.
Old Jun 3, 2002 | 10:51 PM
AbaZ's Avatar
Well I was told the engine was bought at a JDM engine supplier, maybe not.. all I know is that the engine code is a b18c5 with an unmarked tranny sitting in the corner of our shop and I was a bit curious about it.
either way I am going to buy it, boss said 350 bucks takes it.. No head but I have a few b16a heads that should work.
I just wanted to know more info about the tranny.
thanks
Jeff
Old Jun 3, 2002 | 10:54 PM
Reid's Avatar
Global Moderator
SHADY!!!
Old Jun 4, 2002 | 01:12 AM
acuracing's Avatar
SHADY!!!
I'll buy it for $350 if he doesn't take it. Won't be shady for me.
Old Jun 4, 2002 | 04:17 AM
jond's Avatar
Heres something to think about before you buy it.
Run the VIN number in carfax. If its stolen, you can get $10,000 from HEAT.
Old Jun 4, 2002 | 05:00 AM
uNF$@#!'s Avatar
Default Re: Are all Type R tranny's LSD equipped? (jond)
b18c5 sitting in the corner of a shop...odd....
Old Jun 4, 2002 | 05:25 AM
jond's Avatar
Default Re: Are all Type R tranny's LSD equipped? (00-0187)
$5,000 setup for $350.... odd...
Old Jun 4, 2002 | 05:38 AM
TsunamiZC's Avatar
its either a blown block, or a stolen motor....your call , but somehting i learned in those after school program shows tells me its wrong
albertaEK
33
Nov 10, 2007 11:51 AM
NA gs-R 05 C
May 27, 2003 01:14 AM
integraautox
Apr 5, 2003 04:06 PM
Type RS
Nov 18, 2002 10:00 PM
