just changed the clutch and no pedal!!!
Old Jun 4, 2007 | 09:26 PM
88crxdxfastwhip's Avatar
Default just changed the clutch and no pedal!!!
OK i have a 90 honda accord lx, and the clutch burned out so i put a new one in.
I had my friend pump the clutch pedal as i bled the system.We did this for about 30 mins and there was no pressure on the pedal at all.If you pushed it down about middle ways it drops to the floor,Then you have to pick it up with your hand.I was getting fluid out of the bleeder valve like normal but still no clutch pedal pressure.What is the problem?????? PLease help!!
Old Jun 5, 2007 | 04:38 AM
IK_Noodle's Avatar
Default Re: just changed the clutch and no pedal!!! (88crxdxfastwhip)
Do you know how to bleed the clutch properly? My pedal was just like that after I changed my clutch and it just takes time to get all the air out.
Old Jun 5, 2007 | 06:57 AM
j-spec_cc2's Avatar
i was having this same issue with my vigor. wasn't because of a clutch replacement though, but my clutch slave cylinder was gone/on its way out. that could be your problem.
Old Jun 5, 2007 | 01:05 PM
Default Re: (j-spec_cc2)
I just fixed it!!! all i did was gravity bleed it then bleed it regular, and it works great.
my94d16y8coupe
Transmission & Drivetrain
Oct 18, 2011 06:41 AM
Kyle244R948
Nov 26, 2008 01:25 AM
B18Redline
Nov 13, 2007 11:09 AM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
blkgsr03
14
Sep 16, 2004 05:19 AM
