clutch cable snapped ???
my clutch pedal on my 1990 crx si has no pressure. basically its on the floor.
I heard a snap/bang .
could it be the cable ?
I can turn the car on without pressing the clutch (cant anyways)
but cant get it into gear.
I can only get into gears with the car off.
UPDATE:
The problem was a lil plastic spacer that broke, connected to the top of the pedal assembly.
Modified by Rob. at 6:16 PM 6/5/2007
UPDATE:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">One way to find out is to pop the hood and see if the cable is still attached or just came loose..</TD></TR></TABLE>
cable is still attached to the tranny and into the firewall.
no pressure on the clutch? Can you manually pull the lever where the cable is attached to on your tranny and see if it'll go in gear? I'm thinking the clutch fork broke or hopefully just the spring...but either way, you may have to open it up imo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">no pressure on the clutch? Can you manually pull the lever where the cable is attached to on your tranny and see if it'll go in gear? I'm thinking the clutch fork broke or hopefully just the spring...but either way, you may have to open it up imo
which lever ?
http://img.photobucket.com/alb...5.jpg
</TD></TR></TABLE>which lever ?
My bad, I thought you had a Bseries tranny...anyway, looking at your pic, try manually tugging on the lever where your tranny is attached to...you know, pull it up and see if you're clutch will engage. If you step on the clutch pedal, does that lever move?
i had the same exact problem w/ mine... what happened is the plast screw thingy to adjust the clutch snapped & broke... the only way around it is to buy a new clutch cable... & go OEM... cuz i used cheap **** from autozone & i am regretting it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak »</TD></TR><TR><TD CLASS="quote">i had the same exact problem w/ mine... what happened is the plast screw thingy to adjust the clutch snapped & broke... the only way around it is to buy a new clutch cable... & go OEM... cuz i used cheap **** from autozone & i am regretting it...</TD></TR></TABLE>
what plastic screw ? you mean the nut ?
My clutch cable snapped a month and a half ago, and i replaced it with one from auto zone... and yesterday it snapped again. The first time the plastic thing broke, but yesterday the cabel snapped from the inside... but i heard you say something about auto zone cuz my homie works there and he hooks it up thats why i go there, but might it be that that **** is cheap??? the cable said it is made in taiwan... and i know **** from taiwan ******* sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinks11 »</TD></TR><TR><TD CLASS="quote">My clutch cable snapped a month and a half ago, and i replaced it with one from auto zone... and yesterday it snapped again. The first time the plastic thing broke, but yesterday the cabel snapped from the inside... but i heard you say something about auto zone cuz my homie works there and he hooks it up thats why i go there, but might it be that that **** is cheap??? the cable said it is made in taiwan... and i know **** from taiwan ******* sucks
Get an OEM one, it is made of better material.
</TD></TR></TABLE>Get an OEM one, it is made of better material.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
do u mean that the one from the honda dealership??? how much does it run for??
</TD></TR></TABLE>do u mean that the one from the honda dealership??? how much does it run for??
do u mean that the one from the honda dealership??? how much does it run for??</TD></TR></TABLE>
They run for about $24 or so.
They run for about $24 or so. </TD></TR></TABLE>
Its $55... i called them and the dumbfuck at the parts department hung up on me lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knite force »</TD></TR><TR><TD CLASS="quote">Problem solved now buddy?</TD></TR></TABLE>
YUP
YUP
trippy..this happened to me last night
clutch cable broke..the pin that connects to the pedal snapped.
i installed a new acura one and dang the clutch pedal is so soft and smooth now,but it works
slayerP
Apr 5, 2008 01:34 PM
philkehn
18
Sep 14, 2006 04:49 PM
CRX+MaAN
Jul 12, 2006 01:30 PM
