need opinion brake upgrade for 88 crx hf
Old Jun 4, 2007 | 05:20 PM
x i b v r i a n's Avatar
Default need opinion brake upgrade for 88 crx hf
hello guys,
i need your opinions
i have stock 88 crx hf, would liket to upgrade the front brakes and also thinking to do rear disc brakes.
if anyones has opinions pls lmk
thanks in advance !
Old Jun 5, 2007 | 06:01 AM
~sp33~'s Avatar
EFB055
When the crx was 'upgraded' to rear discs, its stopping distance also increased.
Old Jun 5, 2007 | 06:30 AM
CRX Toad's Avatar
Default Re: need opinion brake upgrade for 88 crx hf (xibvrian)
https://honda-tech.com/zerothread/1508680
Old Jun 11, 2007 | 09:37 PM
roastbeefrichie's Avatar
https://honda-tech.com/zerothread?id=1484555
Old Jun 11, 2007 | 09:38 PM
Default Re: need opinion brake upgrade for 88 crx hf (roastbeefrichie)
https://honda-tech.com/zerothread?id=1811368
Old Jun 11, 2007 | 10:30 PM
HonDelso's Avatar
get 90-91 4door ex front knuckles.
you can use any 10.3" set up but the 90-91 ex more symmetrically the same because it's an EF. In turn they are harder to come by because of age.
for the rear if you want to upgrade those
any 88-00 with rear discs, and use 88-91 crx si e-brake cables.
Old Jun 12, 2007 | 05:17 PM
Default Re: (HonDelso)
Thanks for everyone reply
my neighbor has 92 integra 2 door, he's about dumping the car to a junkyard since it basicly striped out.
he sold me his front and rear complete disc brakes for 100bucks, so i bought it.
he said it should be bolt on to my hf but might have do light mods.
can u guys help me with some input?
what other parts i need to get before i can install the disc brakes.
thanks in advance
Old Jun 12, 2007 | 05:30 PM
Crx Jimmy's Avatar
Default Re: (xibvrian)
I would get all new lower and upper ball joints, tie rod ends, rotors, pads, new SS lines, new fluid, some caliper grease to grease the caliper slides.
Old Jun 15, 2007 | 08:58 AM
Default Re: (Crx Jimmy)
thanks for ur input crx jimmy , i tought about that too. I haven't touch them yet , i just got them few days ago and im busy work and school.
im sure someone has done this already, i just need a confirmation that 92 DA front and back rear disc brakes system would work to 88 hf, and if any mods what would that be? Do i need to get DA brake master cilynder and brake booster too?
thanks in advance guys !
Old Jun 15, 2007 | 09:02 AM
CRX Toad's Avatar
http://crf50.no-ip.com/fourthg....html
Old Jun 15, 2007 | 09:16 AM
ef dino's Avatar
http://fastbrakes.com/shop/index.php?cPath=28_37
Old Jun 15, 2007 | 09:17 AM
Default Re: (CRX Toad)
crx toad, thank you boss ! also xskiesgoblackx
Old Jun 18, 2007 | 11:40 AM
installed 93 da front knuckles on to my 88hf with new brembo blank + honda oem brake pads braking waaay beter now , next week will do rear disc conversion also from 93 DA
btw, the upper control arm joint of my 93 DA knuckles both of are out.
can i just buy the ball joint alone? or do i have to buy the whole upper control arm?
and do you guys know if protane or es selling this stuff alone?
lmk guys
thanks in advance !
mxler8
21
Oct 17, 2004 07:46 AM
b16crx0062004
Aug 27, 2004 10:18 PM
3sixtycrew
Dec 4, 2003 06:39 PM
EFing8
Feb 5, 2003 05:14 PM
