Half shaft leaking
Old Jun 4, 2007 | 05:01 PM
BoostinEJ1's Avatar
Default Half shaft leaking
I'm going to assume its because of the seal on the tranny although it looked perfectly fine before I installed the tranny to the motor. I called up my local Honda and the jackass there said there is no seal on that side just the other side. I can't seem to find the part # on slhondaparts or majestic so does anyone know if its the same seal as the one the axle goes straight into? Thanks
Old Jun 4, 2007 | 05:13 PM
LowTEC SaiMike's Avatar
Default Re: Half shaft leaking (FBP_EM1R)
not sure if its on the tranny side or the half shaft side but yes there is a seal in there
Old Jun 4, 2007 | 05:40 PM
BoostinEJ1's Avatar
Default Re: Half shaft leaking (BomBoi)
yea i know there is one on the axle side but im told there is the same exact seal on the half shaft side...
Old Jun 4, 2007 | 05:46 PM
slowcivic2k's Avatar
They are both the same part, I when through a clusterF$*K trying to get my halfshaft to stop leaking trans oil, never use any other seal other than a honda seal, it fits so much tighter around the yoke. Those seals get worn out and lose tension over time, Mine was extremely worn compared to the new honda seal.
Old Jun 4, 2007 | 06:05 PM
BoostinEJ1's Avatar
Default Re: Half shaft leaking (slowcivic2k)
alright cool ill pick one up tomorrow, mine "looks" brand new but it cant hurt to change.
Old Jun 4, 2007 | 06:51 PM
casmall08@yahoo.com's Avatar
The output shaft seals on the tranny are two different parts i recently replaced mine & found out the hard way Napa is the only place that had mine in stock everyone else was special order. about 10$ all together
Old Jun 6, 2007 | 02:15 PM
Default Re: (casmall08@yahoo.com)
DONT BUY NAPA SEALS. They look nothing like the oem piece, which has a rubber protruding lip, plus it seals like crap, I went through three of them, a halfshaft, and finally an oem seal to fix my tranny leak. Napa and places like autozone have two different seal types, and they list the wrong parts for the b16 trans (for some reason, they think the S40 D series trans uses the same parts as the S80 and S4C trans)
jphil101
Apr 25, 2012 08:16 AM
aaronfelipe
Transmission & Drivetrain
Mar 24, 2009 03:27 PM
NightHawkBlack-R
Nov 3, 2008 03:34 AM
Chrislow
Nov 8, 2002 11:07 AM
