my first twin scroll manifold (not honda)
Old Jun 4, 2007 | 04:22 PM
.john.'s Avatar
Default my first twin scroll manifold (not honda)
i think the wastegate might be too small but overall im happy with this manifold. im feeling a little more confident with welding these weld l's now, thanks to all the good reads here. comment away
Old Jun 4, 2007 | 04:35 PM
ROTARY's Avatar
looks awesome, i have the same turbo divided 1.0 AR that im going to use on a 13b-rew but im going with 2 wastgates.
why did you use a t04 flange instead of a t4?
Old Jun 4, 2007 | 04:43 PM
weiRtech's Avatar
OG Fabricator
looks good to me. love to see the setup complete when you get there.
Old Jun 4, 2007 | 05:05 PM
.john.'s Avatar
Default Re: (ROTARY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">looks awesome, i have the same turbo divided 1.0 AR that im going to use on a 13b-rew but im going with 2 wastgates.
why did you use a t04 flange instead of a t4?</TD></TR></TABLE>
whats the difference? this was just the flange that came with the turbo from atp
Old Jun 4, 2007 | 05:29 PM
ROTARY's Avatar
the divided housing t04z's from atp have a t4 footprint.
just wanted to mention it in case you haven't noticed
Old Jun 4, 2007 | 06:27 PM
Bailhatch's Avatar
Id be really curious to see if rotating the WG to either align or make perpendicular the divider and the WG outlet. Seems like it would control boost better with the outlet and edge of the divider lined up or maybe not.
The work looks great too looks even cleaner than your first ones you put up here.
Old Jun 4, 2007 | 06:55 PM
drumking15's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">Id be really curious to see if rotating the WG to either align or make perpendicular the divider and the WG outlet. Seems like it would control boost better with the outlet and edge of the divider lined up or maybe not.
The work looks great too looks even cleaner than your first ones you put up here.</TD></TR></TABLE>
it really shouldnt matter...the benefits of the split pulse are noticed mostly to my undertstanding before desired boost pressure is reached.....aka spoolin time decreases...once the gate opens im assuming it has minimal side travel or the piston would be gallin inside the stem....but the exh gas is going to take the path of least resistance...which shouldnt be much...i see your point on placement but i think once pressure is reached itll creep open and if anything the minor boost control spike on on side of the eq. would be balbced by the short coming of the other side per se....
BMCRace
Welding / Fabrication
25
Dec 2, 2009 02:33 PM
MazworxRacing
33
Nov 29, 2009 08:40 PM
Teglove2
56
Jan 3, 2009 05:13 PM
905_Legend
20
Nov 2, 2006 01:28 PM
egturbo
Jun 24, 2004 11:39 PM
