speedometer and check engine light problems...
Old Jun 4, 2007 | 03:21 PM
hatch_'s Avatar
Default speedometer and check engine light problems...
i switched my throttle body and then my speedometer died. i checked and cleaned the plugs too, but it still wasnt working. beforehand, my speedometer would die, but it was only once in a long time. and now, it hasnt been working at all. the check engine light also turns on after driving the car around for like 5 mins. the engine still seems fine and it doesnt stall or anything. and right after i turn the engine off, the engine light dies. but then after driving it around again, it comes on. any ideas? thanks in advance.
Old Jun 4, 2007 | 03:24 PM
FG2 chilotz's Avatar
Default Re: speedometer and check engine light problems... (hatch_)
Had the same problem and after checking all the fuses under the dash I found two of my fuses blown out so I'd start there. Good Luck
Old Jun 4, 2007 | 04:07 PM
hatch_'s Avatar
checked the fuses and none were blown...
Old Jun 4, 2007 | 04:19 PM
Default Re: (hatch_)
humm...... did you clean the IACV and set the TPS correctly ? Cleaning the speed sensor on top of the tranny would and might help try that. As far as your CEL I would see what code its calling for and start to get a fix on the code ASAP. Good luck bro
ericrcan
Nov 24, 2012 07:54 PM
blaze.1
Sep 24, 2009 11:04 AM
ryanminer
Oct 17, 2008 08:52 AM
lowered94accord
Mar 16, 2007 08:27 AM
Chicano
May 8, 2005 08:43 PM
