What wheels will clear the Wilwood 12.2"/Dynalite setup?
Old Jun 4, 2007 | 11:49 AM
JamesL's Avatar
Default What wheels will clear the Wilwood 12.2"/Dynalite setup?
After tracking and abusing a set of SSR Comps (16x7.5", 4-100, +43)... I bought a set of Enkei RPF1s, identical stats only they are 7" wide.
Turns out the RPF1s have a thicker "lip" in the interior portion of the wheel where the spokes meet the outer rim. This causes interference with the caliper and it doesnt look like a wheel spacer will help (the wheel rubs the caliper on the top and bottom portions)...
Basically, I would have to do some major grinding on the caliper to get it to work with the Enkeis.... I looked at the SSRs and the interior is flush/flat all the way to the spokes, hence why they cleared.
I need some help with other wheel besides SSR comps that will fit this Wilwood setup.... Any ideas guys?
Old Jun 4, 2007 | 12:17 PM
Voyage34's Avatar
Default Re: What wheels will clear the Wilwood 12.2"/Dynalite setup? (JamesL)
team dynamics have usually had pretty damn good brake clearance, to the point that ive heard (quote of a quote from someone at fastbrakes.com confirmed in archived posts) that their 15x7's will clear the 12" wilwoods
if youre looking for 16" sizes i would fully expect those to fit.
they are heavier than either the rpf-s's or the ssr's, 13lbs in 15" sizes vs 9ish lbs for 15's of the other two
Old Jun 4, 2007 | 04:40 PM
JamesL's Avatar
Unfortunately, Team Dynamics doesn't make 16" wheels...
Please correct me if Im wrong.
Edit: And it believe it is the fastbrake Wilwood 11" Dynalite kit that is suppose to fit under some 15" wheels.
Old Jun 4, 2007 | 05:21 PM
Voyage34's Avatar
Default Re: (JamesL)
16" sizes are listed on their website
Again, i cant say for absolute certainty whether or not the 15" TD wheels fit the 12.2" brakes since i havent tried to fit that combination myself, but i was drawing my references from this thread, wherein user Armaan apparently emailed fastbrakes <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armaan &raquo;</TD></TR><TR><TD CLASS="quote">Just got an email from Brian. The Pro Race 1 and Pro Race 2 in 15x7 will clear the Wilwood 12.19" big brake kit.</TD></TR></TABLE>
granted thats the TD Pro Race 1 and Pro 2, not the Pro 1.2 i lined above, but i would expect similar caliper clearance on the 1.2 vs the 1.
it might also be worth a call to fastbrakes or the like to pick their brains a bit
Old Jun 4, 2007 | 06:19 PM
JamesL's Avatar
Ill be damned... Id could of sworn they didnt those black TDs in 16".
Id personally like to use this as an excuse to pick up a set of Volk Ce28Ns... Im guessing they will clear the Wilwood dynalites.
Old Jun 4, 2007 | 09:14 PM
Voyage34's Avatar
yeah think the volk's were another that i saw browsing through wilwood threads for my first response
TD- heavier, cheap, lots o clearance and durable as all getup
volk- lighter (lots) but $$$, no idea as to how tough they are
either way sounds good
Old Jun 6, 2007 | 11:32 AM
JamesL's Avatar
Who is the US dist for Team Dynamics?
Hondakid09si
Mar 30, 2015 02:51 PM
maxogsr
13
Jan 11, 2015 12:36 AM
MagneMike33
Honda Civic (2001 - 2005)
Jul 3, 2009 04:01 AM
SlowB16
May 27, 2008 02:44 PM
