Get Rid Of Annoying Door Open Beeping??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4twenty_CRX »</TD></TR><TR><TD CLASS="quote">What do I disconnect to get rid of the noise?</TD></TR></TABLE>
I would assume you could just find the "speaker" (it's actually more like a little chime) and remove it.
The speaker for this is above the rear view mirror. Take the plastic capp off and disconnect.
(spent hours looking for it, disconnected the wrong one, blah blah blah. PITA. Should have just asked sooner.)
you could just take out the single phillips head screw that holds each door sensor on and unplug/tape up the wire that plugs into it.
Is that the same speaker that doesn't shut up if someone unbuckles? If so I'm going to rip that thing out now. I have a kind of long driveway and everytime I have someone with me they unbuckle while I'm about half way up and I have to listen to that thing go on and on.
or you could just pull out the fuse, I cant remember if that fuse runs the radio too, but right now my fuse is pulled out and everything runs fine no beep
HATCHingMN
18
Nov 23, 2003 12:59 AM
