Air to Water INTERCOOLER setups / charge cooler setups please
I need some pictures/specs of charge-cooler setups ideally on B16a civics
Air to water intercoolers, what manifold you used, what heat exchanger etc.
Really need your help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 »</TD></TR><TR><TD CLASS="quote">wouldnt the intercooler not work as well because as soon as the air travels through the supercharger it will be hot again?</TD></TR></TABLE>
Yes.
I, ve seen Army recovery vehicles w/ two turbos and two superchargers on a desiel motor but it had a elaborate induction system and would use the superchargers from idle to about 1500rpm then the gates would switch after the turbos had built boost and run the turbos from 1500 to 2800 rpm. Hard to see the piping but youd think the jrsc is nothing more than a restriction in that set up. Unless there is more to the induction system.
Yes.
The intercooler is only for the turbo. The SC is only for low RPM torque and spooling the turbo. Once the turbo builds boost, the SC is bypassed. Here's how the system works, although this setup has an air-air FMIC:
https://honda-tech.com/zerothread?id=1293497
Modified by rmcdaniels at 12:27 AM 6/5/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComposiMo »</TD></TR><TR><TD CLASS="quote">
What kind of heat exchanger is that or where did you buy it from? how much?
what power are you making?
Looks nice
</TD></TR></TABLE>What kind of heat exchanger is that or where did you buy it from? how much?
Looks nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">PWR makes barrel intercoolers like that:
http://www.pwr-performance.com/intercooler.htm</TD></TR></TABLE>
i dislike the pwr intercoolers, do you know how hard it is to isolate those intercoolers from heat soak?
is this for a drag only or street car?>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenej8power »</TD></TR><TR><TD CLASS="quote">more info and pics!
</TD></TR></TABLE>More pics of that setup and the fab work can be seen here:
http://www.iconmedia.tv/icon_g....html
The intercooler is a PWR 10" Water-Air Intercooler. The tank in the engine bay is a water holding tank, and there is a separate heat exchanger for it in the front end of the car
Thanks for all this info guys, I think im going to sell my heavy xs-power heat exchanger and buy one of these PWR intercoolers. Thanks for all the info and help guys.
Any more pics of different setups? seeing how the turbo is plumbed in helps me greatly
If you really want to isolate it, IE insulate it, mcmaster.com has some 1800F ceramic insulation thats actually rather cheap. Its white and slightly gritty, but 1" (2 layers) of it makes the 900F+ turbine feel ~100F. If you want it to stay and look more baller, you can top it off with a aluminum-backed fiberglass mat, make it look shiney.
My guess is that CRX has the piping routed in front of that rad & around it to the IC.
From: That's the wrong tone... I'm Skunk2 certified.
oh man, i'd kill to see some vids of that car. the rest of that site has more awesome fab work.
</TD></TR></TABLE>oh man, i'd kill to see some vids of that car. the rest of that site has more awesome fab work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">My guess is that CRX has the piping routed in front of that rad & around it to the IC.</TD></TR></TABLE>
You'd be guessing wrong then
