87 carb swap to d16y5
Old Jun 4, 2007 | 02:56 AM
dj273's Avatar
Default 87 carb swap to d16y5
I just want to find out what going to go on with this swap. i really wanted to know about the timing issue. and can i put my 87 hf trans on the d16y5
http://www.redpepperracing.com/gallery/v/redrex/
Old Jun 4, 2007 | 04:49 AM
vdawg559's Avatar
why would u wanna do that?
Old Jun 4, 2007 | 11:40 AM
dj273's Avatar
Default Re: (vdawg559)
why would i want to do what? the swap cause The engine is very good on gas and its made for what i need miles not *****. and keep my trans? that just as easy I'm keeping mine cause its cable and not hydro.
so is the anyone that can help me.
Old Jun 4, 2007 | 01:55 PM
jlicrx's Avatar
Default Re: (dj273)
the D16Y5 engine will not bolt to your transmission - the only cable clutch transmissions that will bolt to the Y5 are the 88-91 L3 transmissions - the Y5 with L3 transmission will not bolt into your car and will require fabricating of all of the mounts in order to install it - not to mention the fact that your car does not have a fuel sytem compatible with the fuel injected engine - to run the fuel injected engine will also require that you essentially rewire the entire car for the engine portion
Old Jun 4, 2007 | 07:31 PM
dj273's Avatar
Default Re: (jlicrx)
okay I know that i have to rewire the whole engine compartment. I have the engine harness off a 95 vtec and the p28 ecu. I know that I wont be able to run the e part of the y5 but 2 of my friends work for honda and there going to wire the inside for the check engine light and all of the wiring that needs to be switched. so I know that this isnt the best switch. What car does the 88-91 L3
transmissions come off of?
Old Jun 4, 2007 | 07:34 PM
dj273's Avatar
hey I just noticed that your from cs. I just left the for here. and I plan on coming out there this fall to pick up my stuff. maybe we could talk then?
Hoopdie91
Nov 5, 2017 06:05 PM
littleredcivic88
Feb 17, 2009 02:24 PM
civicxxman
Feb 26, 2008 02:22 PM
straightRazor
Mar 9, 2007 12:38 PM
.nate
15
Oct 12, 2001 08:57 AM
