dpfi to mpfi swap -[major problems]-
Old Jun 4, 2007 | 02:43 AM
minime-civic's Avatar
* B A N N E D *
Default dpfi to mpfi swap -[major problems]-
okay so it runs, [like ****] but it runs and it revs really slow, and #1 isnt getting fuel. and then i saw smoke, so i went under the car to see what it was, and my exhaust from the header to muffler orange hot, someone please tell me how to make it run right...see i'm no noob to the honda world, though i am to obd-0 but ive never seen this before. heres the site i got the info off of.
http://www.angelfire.com/d20/h....html
Old Jun 4, 2007 | 05:04 AM
vdawg559's Avatar
iono how to help. but dere is a forum here to help
Old Jun 4, 2007 | 05:24 AM
DenzComp's Avatar
I'm getting ready to do the same swap. After searching through write up after write up I came across this one...
http://hondaswap.com/swap-arti...49557/
it seems to be the easiest to understand. Go over that and double check all your wires.
PS. You have the SI Dizzy and PM6 ECU right?
Old Jun 4, 2007 | 10:59 PM
* B A N N E D *
Default Re: (DenzComp)
got it all figured out sir
thank you
Old Jun 4, 2007 | 11:55 PM
low91rex's Avatar
Default Re: (minime-civic)
What did you do?
Old Jun 6, 2007 | 04:56 PM
89civicsi*'s Avatar
i just completed the swap dpfi to mpfi. but it has slow exceleration, and or no power....its running on 4 all cylinders..is there simply wiring issue i over looked? this is the link i used. what did you do to fix your problem?
http://www.geocities.com/teampimports/fuelinj.html
Old Jun 6, 2007 | 05:27 PM
Efbluevtec's Avatar
Default Re: (89civicsi*)
did you swap the 2 wires on both ends on the TPS sensor.... the dual point wire run opposite directions of the Multi port.
ThaBread
30
May 11, 2013 01:25 PM
project rex
Sep 19, 2004 12:28 PM
USDMMARK
Feb 23, 2003 04:51 AM
