d16a6 wont start after swaped
Hey guys what’s up I just finished my swap every thing went ok I had to change a bunch of stuff over from the d15 (stock sol s motor) to the new d16a6 (90 civic si motor) every thing is in and bolted up and hoses on wires plugged in but it wont turn over it almost did it wants to but nothing I have fuel almost like its not firing right. I have the right firing order ( I believe 1-3-4-2) did I have to do any moods to the dizzy ( I have the dizzy from the sol's d15 on the d16a6 motor if anyone can help it would be great I will list all the stuff I swapped from the sol motor to the 90 civic si d16a6 motor.
1. Intake manifold and all wires and sensors
2. dizzy
3. Whole cooling system from the water pump to the thermostat housing
4. Front where the upper radiator hose meats the motor
5. Alternator
6. Starter and transmission
7. Driver side motor mount
8. Radiator and fan
9. Ecu and harness
So all the stuff listed was removed from the d15 stock sol s motor and swapped to fit the 90 civic d16a6 motor (note d16a6 obd0 sol d15 obd1)
Let me know what every body thinks ill have pics and maybe video up of the motor trying to start so you can get an idea
Thanks’ Sal
(hit me up 631-398-8390)
2. dizzy
5. Alternator
8. Radiator and fan
9. Ecu and harness
Thanks’ Sal
xW01FxGANGx
Jul 13, 2014 07:54 PM
