98 integra clutch squeeks, how do I fix this?
Old Jun 3, 2002 | 08:12 PM
sfr4dr's Avatar
Default 98 integra clutch squeeks, how do I fix this?
Has anyone ever experienced this with their newer integra? Some of my old vehicles did this and the clutch fork needed to be lubed all the time to keep the noise away. The squeeks can be felt through the pedal and it takes away from the smoothness of the pedal stroke. What should I do?
Old Jun 3, 2002 | 08:38 PM
junglistgsr's Avatar
Default Re: 98 integra clutch squeeks, how do I fix this? (sfr4dr)
is there any fluid where the pedal assembly meets the firewall? if so it means you have a leaky clutch master cylinder which can cause the squeeks. The slave release cylinder also can squeek but that would sound like its coming from the front of the tranny where its located.
Old Jun 3, 2002 | 08:43 PM
TakaIntegra's Avatar
Default Re: 98 integra clutch squeeks, how do I fix this? (junglistgsr)
Take out the clutch fluid and refill. The clutch noise will go away.
bbrian
Transmission & Drivetrain
Jun 14, 2013 10:09 AM
gnarlycs
11
Jun 10, 2012 05:19 PM
K-Spec
Sep 26, 2006 11:30 PM
TyPe_R_GuY
Apr 4, 2004 12:23 AM
sa21199
Aug 22, 2001 10:37 PM
