Suspension & Brakes Theory, alignment, spring rates....
LOWER CAR
Old Jun 3, 2007 | 10:53 AM
'Accord Ex''s Avatar
Default LOWER CAR
I wanted to lower my car but I don't know how far a want it lowered. My friend says 2" will slam it and I don't know how low to go. I just want to be low but can still drive it. 98 Accord Ex sedan
Old Jun 3, 2007 | 02:36 PM
chrisw85's Avatar
Eibach pro-kits will lower it nicely without being 'slammed' and still give you increased handlign over stock and not too harsh a ride over stock. Remember the lower you go the higher the spring rates you'll want to prevent bottoming out and that can mean a harsher ride. The higher spring rates should be matched to appropiate performance dampers like Koni Yellows, or a less expensive alternative is the Tokico Illuminas. If you stock shocks are worn, you could very just get Koni Special 'Reds' to match the prokits; no need fot he yellows or illuminas for the prokits.
I suppose you could go H&R sports and Koni Sport 'Yellow' dampers, a lot of people like this setup very much a little lower than the Prokits and not all that much harsher.
Old Jun 9, 2007 | 02:34 AM
The Si's Avatar
Default Re: LOWER CAR ('Accord Ex')
Lowered it 2", if you think its too low then raise it up a bit. If its still high for you, lower it a bit lower. Easy as that and the lower you go the harder it is to drive it.
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
cmdr430
Honda S2000
10
Apr 17, 2005 11:05 PM
gsr_to_the_MAX
Jan 31, 2005 05:06 PM
hybrid901
Honda S2000
Jul 10, 2004 02:24 AM
Sittin in my Sparcos
Jan 15, 2003 08:11 PM
