Question about tires for my GSR Blades
Old Jun 3, 2007 | 10:19 AM
mikeunreal2's Avatar
Default Question about tires for my GSR Blades
I noticed the original tire size that came on blades is 195/55/15. Is this the size I should run or should I got with 195/50/15s? What do you guys think.
Mike
Old Jun 3, 2007 | 10:28 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Question about tires for my GSR Blades (mikeunreal2)
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">
What size tires should I get?
<FONT SIZE="4">The proper size depends on your car, not just the wheels you are using.</FONT>
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16
<FONT SIZE="4">For an Integra or '97-00 Civic, the following sizes are usually best:</FONT>
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16, 215/45-16
17" - 205/40/17
Old Jun 3, 2007 | 10:58 AM
Default Re: Question about tires for my GSR Blades (nsxtasy)
my car is lowered about 2.25 inches or so. i can barely have a wheel gap. considering this; does it matter if i go with the 195 or 205?
Mike
Old Jun 3, 2007 | 11:16 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 &raquo;</TD></TR><TR><TD CLASS="quote">my car is lowered about 2.25 inches or so. i can barely have a wheel gap. considering this; does it matter if i go with the 195 or 205?</TD></TR></TABLE>
You should be able to use either the 195/55-15 or the 205/50-15, even with the lowering. If you encounter problems, you're probably better off raising the car up a little bit.
Clearance for both is about the same. (The 205/50 is 10 mm wider, but it's 10 mm smaller in diameter.)
bbyass
Sep 22, 2008 03:01 PM
c-r-x
Mar 19, 2008 01:48 PM
T3@MD3FC*N
Jul 23, 2007 03:19 PM
EGII
May 1, 2007 04:13 PM
xelloss
Apr 12, 2007 09:50 AM
