Installed cams now car wont turn over, sounds like no compression
Old Jun 2, 2007 | 10:23 PM
crawlin's Avatar
Default Installed cams now car wont turn over, sounds like no compression
i switched my EF1 m23 cams to gsr cams put everything back together correctly and the car wont kick over. i have spark and fuel so those can be ruled out. the cam gears are pointing up and the crank pulley is lined up on the block im out of ideas as of now. motor will turn but it sounds like there is no compression just a whining noise almost.
any input appreciated
Old Jun 2, 2007 | 11:13 PM
b20vtech's Avatar
Default Re: Installed cams now car wont turn over, sounds like no compression (crawlin)
try re-adjusting the valves.....
Old Jun 3, 2007 | 07:56 AM
crawlin's Avatar
Default Re: Installed cams now car wont turn over, sounds like no compression (b20vtech)
could that make that much of difference considering the car was running perfectly fine before i put the other cams?
Old Jun 3, 2007 | 09:40 AM
crawlin's Avatar
put my EF1 cams back in and car started up. so assuming my valves are out of adjustment.
i would think to put the gsr cams in and adjust them then the car should fire up.
Modified by crawlin at 12:00 PM 6/3/2007
Old Jun 3, 2007 | 04:01 PM
crawlin's Avatar
gsr cams in with adjustment fixed the problem
Modified by crawlin at 2:27 PM 9/21/2007
g23cg5
Nov 15, 2013 04:58 AM
lsvtechatch92
Mar 17, 2010 08:05 AM
reboosted
Oct 30, 2009 04:50 AM
tomlinson619
May 22, 2006 07:59 PM
Junglist
Jan 3, 2003 08:59 PM
