Changing Automatic transmission fluid
I have a prelude but I have to help my friend with an automatic 04 Civic ex sedan change the transmission fluid. I was wondering what size is the drain bolt (just stick the socket of the wrench in the bolt?) and do I fill the fluid from the dipstick or is there a separate filling place? Pics would be greatly appreciated!
Thanks
-Moh
Thanks
-Moh
Sounds about right.. but use the dipstick to check you are at the proper level. also when you drain an auto tranny you are only draining about a 1/3 of the fluid. remember that the Torque Converter will still have a ton of fluid in it.. so what you can do is the drain and fill and drive, a few times to get most of the fluid replaced.
Good luck..
Good luck..
Pilot King
May 21, 2011 04:31 PM
JennyPooh
40
Nov 4, 2010 11:17 PM
