apex n1 cat-back...
Old Jun 3, 2002 | 06:05 PM
Phil DeVtec's Avatar
Default apex n1 cat-back...
i just received this today and i was checking it out...i noticed that the one end had a triangle connector instead of the regular two-holed oval-like end...it is the end where springs are with the bolts...if you know what i'm talking about at all, then please tell me what i should do...how should i go ahead with the install? please help..thanks
MODS: if you feel that this should go in tech feel free to move it...i just put it here because it seems like more people check here!
Old Jun 3, 2002 | 06:31 PM
Default Re: apex n1 cat-back... (GoSpeedRacer)
ttt
Old Jun 3, 2002 | 06:42 PM
logistixz's Avatar
i believe that end goes into the catalytic converter
Old Jun 3, 2002 | 06:43 PM
RR98DX's Avatar
what civic do you have? that would help allot.
Old Jun 3, 2002 | 06:47 PM
cr00klyn718's Avatar
Default Re: apex n1 cat-back... (RR98DX)
Old Jun 3, 2002 | 06:49 PM
i have a 93 vx...i'm just scared that they sent me the one for the si...should it make a difference??
Old Jun 3, 2002 | 07:57 PM
nope woudnt matter...same model number for all the 92-95 h/b
Old Jun 3, 2002 | 08:26 PM
jdmciviceg's Avatar
New User
you are going to have to take the car to a muffler shop and have the correct piece welded onto your factory piping. I have an N1 on my hatch and I had to have it cut and a plate welded to match up to the N1's piping. Just one of those things.
Old Jun 3, 2002 | 09:15 PM
RR98DX's Avatar
ok here is your deal. your VX has the classic header-cat combo so the b-pipe is longer. they sent you the cat-back for the DX/Si which has the cat under the car so the piping is shorter and is the 3 bolt not the 2. if you want factory fitment and don't want to hack up your N1, send it back and have them send you the N1 for a 96-98 Civic CX/DX Hatchback. it will bolt up just fine and the b-pipe is longer and will run right upto your downpipe and connect with the 2 spring bolts. hope that made sence.
here is a pic i made a while ago to help point this out...
[Modified by RR98DX, 10:18 PM 6/3/2002]
Old Jun 4, 2002 | 04:15 AM
thanks man...i dont really feel like sending it back because optauto is in kali and im all the way in jersey...so if i take it to the muffler shop...what exactly are they going to do? and is my n1 still going to look and perform the same way?? thanks man
or is there anything i can add to make it longer for fit...
[Modified by GoSpeedRacer, 1:16 PM 6/4/2002]
Old Jun 4, 2002 | 05:10 AM
jdmciviceg's Avatar
New User
If you take it to the muffler shop, they are going to cut your factory exhaust and weld the 3 bolt fitting onto your factory exhaust so it will bolt up to your N1's piping. They might put in flex piping which is really better or you will end up with broken exhaust hangers like my car if your motor flexes enough. It will perform just fine. Don't expect a huge difference in performance with the exhaust though. Its still a VX motor.
Old Jun 4, 2002 | 06:33 AM
memphiss13's Avatar
just go to a junkyard and buy an EX/Si header and cat. that would solve your problem
Old Jun 4, 2002 | 06:56 AM
khoalie's Avatar
Default Re: apex n1 cat-back... (rookie2nr)
Old Jun 4, 2002 | 08:42 AM
Default Re: apex n1 cat-back... (khoalie)
yeah..i thought about doing that...so it would definitely work with an si or ex header/cat? does anyone have one that they want to sell...or know anyone who's selling one...thanks a lot guys..i really appreciate it
Old Jun 4, 2002 | 08:48 AM
00MRSi's Avatar
If you can remedy the situation with an EX/SI header than try it. If not, I would just send the exhaust back and tell them to give you the "correct" one. I would not have a muffler shop cut up and hack a brand new exhaust system I paid $500 and change for.. Just MO.. Good luck.
Old Jun 4, 2002 | 10:30 AM
Timmayeg's Avatar
New User
Default Re: apex n1 cat-back... (00MRSi)
i could get you a EX header for 25 and some shipping
Old Jun 4, 2002 | 10:59 AM
so you're sure that the 96-98 cat-back will bolt right up to the 92-95 no problem?? i might go this route...
ex/si header and cat
or
96-98 cat-back...which one should i do??
Old Jun 4, 2002 | 02:40 PM
i think im just going the route of a new manifold and cat...is that all i need?
ex/dx/si...which one should i get to make it fit correctly
Old Jun 4, 2002 | 04:06 PM
RedlineUBRF's Avatar
ex/si is the same probally better than the dx as far as performance
Old Jun 4, 2002 | 04:16 PM
Default Re: apex n1 cat-back... (RedlineUBRF)
okay...so EX/Si it is...but I'm having a really hard time finding this stuff man...can someone help me out...i already emailed the guy from this thread but he hasn't replied...can anyone else maybe find me one...thanks a lot guys...this thing is just causing a major headache!!
Old Jun 4, 2002 | 07:19 PM
jdmciviceg's Avatar
New User
umm....cutting the apexi exhaust would be stupid. the muffler shop will cut the "factory" exhaust to fit to the apexi n1. do what you want but you are wasting your time and money for shipping if you send it back.
JOSEPH
Oct 28, 2007 10:23 PM
JSPECSIR
12
Feb 14, 2006 08:43 PM
Wong Wonder
Feb 4, 2003 10:52 AM
sc2o00
Dec 3, 2002 03:30 AM
X2BOARD
Jun 26, 2001 12:17 PM
